Fahrenheit Endurance teardown and cleaning
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by 343amc, Oct 11, 2014.
  1. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Yeah I need that for the hard to reach back wall.
    ivanhoe likes this.
  2. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Have you greased the actuators?
    ivanhoe likes this.
  3. DexterDay
    Yes. Every season. It's not that hard when you remove the back panel and the control board (unplug stove first)
    ivanhoe likes this.
  4. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    I actually just removed it to sneak a peak, I think I would have to put it into maintenance mode so the arms are extended. As it sits, arms closed nothing to grease.
  5. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
  6. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    :eek:
    Removing the back panel is no easy task when you have a 10" insulated duct there:faint:
    I was looking at possibly removing the cold air box and leaving the duct intact and just pushing it away to remove the cover screws to NEVER put them ALL back. Just the easy to reach ones. I see a cold air box screw on each end, which means 1 must be in the middle and that's blocked!:eek:
    ivanhoe likes this.
  7. DexterDay
    Yep. Extend both the pusher plate and burn plate out all the way so that you can grease the top and bottom of each slide.
    Sorry, never thought about that as I don't have a Cold Air Return hooked up.
    Once you get it off though, you only need the two that you can get to? I would throw the middle screw in a parts bin for when you lose one elsewhere :)
    ivanhoe likes this.
  8. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    How about the blower that's back there? Should that be cleaned?
    ivanhoe likes this.
  9. DexterDay
    Which one. Combustion or Distribution?
    ivanhoe likes this.
  10. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Combustion is on the side, so the distribution I believe is in the rear.
    ivanhoe likes this.
  11. DexterDay
    Both should be cleaned yearly. . But running a filter? The distribution blower can go 2 years
    ivanhoe likes this.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    If you install a flex duct on the upper part of the cold air return will facilitate movement to push aside the cold air plenum box behind the furnace for easier access.
    [​IMG]Something like this.
    jtakeman likes this.
  13. Steve1266
    Steve1266
    Winchester NH
    Behind the ash pan there are two holes going to the back wall is there a plate that is supposed to go over that
  14. Steve1266
    Steve1266
    Winchester NH
    The flame looks good during start up after it stabilizes it’s kind of a lazy flame I've plugged the holes in the fire pot took the plate off the exhaust manifold sealed the air wash I’m wondering if I have the wrong exhaust fan not big enough fins does anybody know the part number for the fan
  15. Steve1266
    Steve1266
    Winchester NH
    Where did you get that fan impeller
  16. ivanhoe
    ivanhoe
    Northern Ontario
    If you go to the Fahrenheit information thread, you'll find the impeller#, I think it's from a Kozi or Quadrafire stove. I don't have it on hand, sorry. On initial start up the furnace is on a higher burn rate for about 20 minutes then settles down to the set burn rate.
    The two holes at the bottom is your exhaust outlet, don't cover it up. There's a plate just above it which needs to be kept clean for upper heat exchanger passage.
  17. ivanhoe
    ivanhoe
    Northern Ontario
