028 help
Discussion in 'Chainsaws and Power Equipment' started by AmarilloSlim, Oct 21, 2016.
  1. clemsonfor
    Dang I have the same things to do on my old truck!! it's on stands now waiting on parts to come in! are we sure your not me or this is an alter profile of me?
  2. AmarilloSlim
    AmarilloSlim
    Amarillo
    Might be. Carrier inner seal were wrong (probably for a 10 bolt instead of a 12 bolt) so buddy his going to source the proper stuff. Pinion and carrier bearing are correct so hopefully a minor mixup. Need to get his truck out of the way so I can start on mine. Ring and pinion and spider gears in the front axle.
  3. clemsonfor
    And again I am working on a 12 bolt!!!:eek::rofl: :lol:
  4. AmarilloSlim
    AmarilloSlim
    Amarillo
    image.jpeg image.jpeg Lol clemsonfor rear 12 bolt. And his front Dana 44 we will be rebuilding at a later date. Probably the only maintenance this thing has ever seen :picard:
    HDRock likes this.
  5. Mag Craft
    Man that thing is nasty. I do not think I have ever seen a ring and pinion that bad before.
    AmarilloSlim and clemsonfor like this.
  6. clemsonfor
    Mine is a rear 12bolt I am working on. I haven't opened the diff, but I hope mine doesn't look like that inside:eek:o_O.
    But I have a corporate 10 bolt on the front
    AmarilloSlim likes this.
  7. clemsonfor
    Back to the saw...I just looked and it's an older model...it's the 032, I was thinking this saw is older than the 028 and 034 and not an easy coil swap..
    Any comments on a coil replacement ?
  8. AmarilloSlim
    AmarilloSlim
    Amarillo
    Believe the 028WB coil like I replaced also fits your 032?
  9. AmarilloSlim
    AmarilloSlim
    Amarillo
    I have a few broken ones under my belt but this one takes the cake! Pinion bearings crapped out damaging the carrier and breaking almost half the ring gear teeth.
    Mag Craft and clemsonfor like this.
  10. HDRock
    Oh, looks like fun, boy!! that sucker is chewed up
  11. HDRock
    Might be better to go to the junkyard and get a whole new rear end
    clemsonfor likes this.
  12. AmarilloSlim
    AmarilloSlim
    Amarillo
    i had similar thoughts but he wanted to keep what he had... I have a 3/4 ton semi float gm axle with 1/2 ton wheel pattern sitting here. The rear axle is salvageable. The front with busted gears is not however.
    clemsonfor and HDRock like this.
  13. clemsonfor
    I would of put
    the semi float in!
  14. clemsonfor
    And is this Lil red barn coil a special electronic coil to replace an older style . for some reason I thought this was an old school system. I think there are several types of ignition on these older saws...right?
    OK I went and looked and there wasn't a coil listed on their site under 032 so something must be different about it. I found someone on ebay a year or so ago that offerers a repair service to fix your coil.
