chimney porn!!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Scotty Overkill, Sep 13, 2016.
  1. boettg33
    boettg33
    Wakefield, RI
    Just a bit drafty there. You must keep the stove cranking to keep it warm inside.
    Star Gazer, Thor, NortheastAl and 3 others like this.
  2. Oldhippie
    Oldhippie
    Ashby Ma
    I rode by about a week ago on one of my motorcycles and might have stopped in but I had 3 other guys with me, all of who haven't got a clue about wood burning.
    But don't be surprised if I pop in sometime.
  3. Flamestead
    Flamestead
    Windsor County, VT
    Please do, it will be great to meet in person and we'll give you the 20 cent tour! We've got the PH back on the kitchen hearth, and a new AS is here, but it won't get installed this year.
  4. Oldhippie
    Oldhippie
    Ashby Ma
    I pick up my AS first or 2nd week in October.
  5. DexterDay
    Here is my flues..
    The wood stove and chimney/flue..
    The pellet stove upstairs and vent..
    The pellet furnace downstairs and vent..
    All have OAK's!! ;)
  6. Thor
    Thor
    Genoa City,Wi
    Wow nice setup. Love the basement. In pick #2 I see your chimney is discolored? Mine looked a little like that last winter. I got a little scared I was over heating it. Is it something I should worry about? Thank you for the information.
  7. brenndatomu
    It is actually from oils in the creosote washing off your cap...it shows on the shiny stainless
  8. Boomstick
    Boomstick Banned
    Saratoga county ny
    Thats cool. Slate lasts indefinitely. And looks awsome. Around here you see them on Victorian and pre- revolutionary era houses and barns.
    Star Gazer, Viking80, Thor and 2 others like this.
  9. NortheastAl
    NortheastAl
    Putnam County NY
    I was raised in a house that was built in 1854, and it had the original slate roof on it until the last family member left in 1993. Never leaked as far as I remember.
  10. tfdchief
    tfdchief
    Tuscola, IL
    I fought a fire in an old 3 story Victorion house several years ago. The fire was in the 3rd story and we had to cut holes in the roof to vent the fire so the guys could work up there to put the fire out. We did and the house was refurbished after the fire. But the slate roof we cut holes in got replaced with regular shingles. Hated to see that. They had been on there for a hundred years. Chief
  11. Thor
    Thor
    Genoa City,Wi
    So maybe my wood was a little to wet? When I cleaned the chimney I barely got anything out of it,
    NortheastAl likes this.
  12. brenndatomu
    No not necessarily, even with dry wood it seems like you will get a little buildup on the cap (unless you run the stove pretty hard a lot) and that is enough to get a little streak like that going on after rain/snow, etc
    Star Gazer, NortheastAl and Thor like this.
  13. Thor
    Thor
    Genoa City,Wi
    perfect that is good to know, Thank you.
  14. tfdchief
    tfdchief
    Tuscola, IL
    Also, SS will discolor like that from heat. Chief
  15. brenndatomu
    That's true, it will. Do you see something there that makes you believe it has burnt?
    I have seen that "top down" discoloration/staining on numerous chimneys (including mine) that have never been overfired. I really doubt that normal operation would be enough to discolor because you can lay your hand on the bottom of a class A chimney, even when the stove is crankin...and the top will be even cooler. And although it is certainly possible, I suspect Thors chimney has not been heat discolored.
  16. tfdchief
    tfdchief
    Tuscola, IL
    You are probably right. However, some SS discolors pretty easily. I have 2 SS chimney caps and one of them is dicolored like that and it has never been over fired. Just throwing that out there as a possibility and nothing to worry about. Chief
    NortheastAl, Thor and Star Gazer like this.
  17. Thor
    Thor
    Genoa City,Wi
    Mine is not like that now, maybe it washed off from rain. I just thought I may have heated it up to much. Thank you all for your help!
  18. NortheastAl
    NortheastAl
    Putnam County NY
    Mine gets like that and the rain gets it off. My cap right now is clean and shiny on the inside and outside, and I haven't cleaned it yet. Rain works wonders.
  19. tfdchief
    tfdchief
    Tuscola, IL
    Of course if it washes off it is not discoloration of the SS. So sounds like you are good to go.
    Chief
  20. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Here it is with the chase top on and the cap!
    Can't wait to get the IS hooked up to this system! Seems like :makeitrain"in the wind right now. I will have about $6,000 into this whole "free heat" system with the IS stove, chimney (cap, 20 ft SS, a T, and interior double wall,), the chase, chase cap, and extra work of siding!:whistle: Thank goodness for CASH or this would have probably been pushing $8,000+ for what the builder wanted to charge me. Got a friend of my dad to build the chase and a friend of a friend to get the chimney pipe (ICC Excell) and install it.
    From my calculations I'll start seeing a payback (actually start saving $) in the 5th season! Figuring that off a $200/month heating bill for about 2800-3000 sq ft. Probably wouldn't be that high though. Man I better stay living here for awhile......
