  1. will711
    will711
    Pocono Mts.
    And the after pics
    gbreda, savemoney, CleanFire and 6 others like this.
  2. subsailor
    subsailor
    Winthrop, Maine
    I'm a little surprised it was that dirty. I tore mine apart today as well and I had just a light coating of ash on the inside of the pipe. IIRC you don't run an OAK. Could that maybe be the difference.
  3. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It needs a cleaning.
  4. will711
    will711
    Pocono Mts.
    And it got one after a ton
    CleanFire, slvrblkk, bogieb and 2 others like this.
  5. will711
    will711
    Pocono Mts.
    I happy that the pipe was only coated with ash no creosote , and that's with 2 90's to get it to the chimney and one to get it out . Pics may make it look worse may be a 1/16 of an inch or less thick .
  6. imacman
    imacman
    Denver, NC
    IMO, those are pretty heavy build-ups. Not sure I'd let mine get to that point. I probably wouldn't let mine go more than about 1 1/2 - 2 tons before cleaning with Lint-Eater.
    gbreda, savemoney, CleanFire and 5 others like this.
  7. imacman
    imacman
    Denver, NC
    What's that doing there? That's going to cause a lot of back pressure.....get that thing into the burn pot where it belongs :D
  8. will711
    will711
    Pocono Mts.
    I hear ya Pete , this was the first year so you see what happens and that is a 4" pipe not a 3" so the stove was'nt chocking itself , but I prolly will pull the pipe mid season for a cleaning , now that I have a bench mark .
  9. will711
    will711
    Pocono Mts.
    That's a CYA before some one says that something is missing from my pics :rofl: :lol::rofl: :lol::cheers:
    eatonpcat, savemoney, MikeSs and 6 others like this.
  10. imacman
    imacman
    Denver, NC
    Especially important with the # of 90's you have.....even though it's 4", all that drag can't help.
  11. imacman
    imacman
    Denver, NC
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Large Flue Plug of The Blue persuasion?
  13. will711
    will711
    Pocono Mts.
    Appreciate all the feed back Pete thanks Bud :thumbs:
  14. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
  15. bogieb
    Cat - unless it is sitting at my feet, then it is a 0.5 second rule
  16. bogieb
    Stupid question time. I thought I had bought a lint eater online, but I opened the box today to clean the P61a's exhaust, and found I had gotten a soot eater. Which, I thought would be fine. However, I couldn't get it to go past the 45 elbow that is about 2' from the outlet. So, here is the question: is the soot eater better? The rods look the same so I don't see how they will go thru - especially the points where the rods connect. Maybe it is a different brand that other people are using (versus Gardus). I don't mind getting something else, but don't want to waste another $25 if I don't have to. EDIT: I see I can get a lint eater Jr. kit (that will attach to the kit I already have for about $15 - but would like confirmation that is what I need.
    And, as an aside, the P43 exhaust is so clean it is still shiny, so I didn't bother with that (I did do the LBT on it earlier in the year) . And yes, it is pipe I see. However, The P61a has a much longer exhaust and I can see that it isn't shiny even after LBT, so want to do preventive maintenance if possible.
  17. slvrblkk
    slvrblkk
    Northampton, PA
    Well she's officially ready to go....although I hope it's a while yet for that.
    savemoney, CleanFire, will711 and 3 others like this.
  18. slvrblkk
    slvrblkk
    Northampton, PA
    Will...did you have the LB on it as you cleaned it?
  19. slvrblkk
    slvrblkk
    Northampton, PA
    B....I have the Deflecto dryer duct cleaning rods that are really stiff and I was able to get that through a very short section of two 90's on my stove...I had a section of rod attached to my drill. Not sure if that helps you out of not.
    gbreda, savemoney, CleanFire and 2 others like this.
  20. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    thats the trouble with letting women go shoppin on their own
