Sharpening Thread
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Jan 27, 2014.
  1. bogydave
    I'm near there with an RS on the saw.
    Bumped a rock today, not sure the damage but saw sparks.
    Can you keep going much more when the cutter gets that short?
    I figure you go until one breaks off, then you've squeezed the max life out of it .
    Will get some pics this evening when I head to the shop & sharpen it.
    Hedgerow and mdavlee like this.
  2. mdavlee
    mdavlee
    Here's some chips from cutting maple last summer.
    HittinSteel likes this.
  3. mdavlee
    mdavlee
  4. charlie
    charlie
    Schoharie, NY
    Try some Timber Savage files,, they are double milled.. I've used them over 10 years ,,,They mill off material quick and with little effort..
  5. Hedgerow
    Hedgerow
    SW Missouri
    I runnem till a few break off...
    mdavlee likes this.
  6. Hedgerow
    Hedgerow
    SW Missouri
    Where are those made?
  7. mdavlee
    mdavlee
    I've never seen them in any shops I've been in.
  8. mdavlee
    mdavlee
    I'm digging for pictures for this thread. The bottom one won a chain build on a stock 3120.
    Chvymn99 likes this.
  9. DexterDay
    How are you forming the rakers? Is that with a Dremel (diamond or tungsten carbide cutter?)?? Or is that file work as well?
    I need to send some chains to one of you for our GTG in May :whistle:
  10. mdavlee
    mdavlee
    Dremel and files but mostly files. That chain had a good 8 hours in it. I'm a little faster than that now with doing 10 of them. It might take me a bit longer with no grinders at all now.
  11. jdonna
    jdonna
    MN
    mdavlee, that is insane.! I got a chuckle.
    Chvymn99 and mdavlee like this.
  12. Hedgerow
    Hedgerow
    SW Missouri
    Each step you take with a race chain takes a good deal of time... First you gotta shape all the cutters, then form all the rakers.. Then you gotta deal with the material inside the cutters...
    The back of the cutters.. And last of all , you give it a couple strokes with the double bevel file...
    Yeah... I spent almost 8 hours on an 84 drive link chain for the last Grantsburg races...
    Hinerman and mdavlee like this.
  13. Hedgerow
    Hedgerow
    SW Missouri
    That chain liked power, but could remove material with it!!
    Did you ever tunnel those teeth??
    mdavlee likes this.
  14. mdavlee
    mdavlee
    No that one wasn't tunneled. I'm sure it would help some.
  15. charlie
    charlie
    Schoharie, NY
    They are made in Switzerland.. One shop by me sells them, but you can get them on Ebay... You'll never use any other file ..They can really make it nice to clean up a rock hit on a cutter.. They last a long time as well..
    fox9988, Hedgerow and mdavlee like this.
  16. Hedgerow
    Hedgerow
    SW Missouri
    I'll have to check those. Out...
    Good files are a pleasure to use...
    mdavlee likes this.
  17. charlie
    charlie
    Schoharie, NY
    I agree, these make sharpening quick and easy.. If the light is right you can see the little filings coming off as you file your cutters.. Double milled they are cutting with 2 milled edges... Probably why they cut so nice..
    mdavlee likes this.
  18. mdavlee
    mdavlee
    New save edge are like that. They're the best I've used so far. I need to order a few more.
    Hinerman and Nixon like this.
  19. MacLaren
    MacLaren
    Howdy fellas, nice thread y'all got goin on here. Awful nice feelin to produce big ole chips in the crosscut. Mike sure helped me with it. I like workin on those gullets too. Anyways, nice seein everyone.
  20. HittinSteel
    HittinSteel
    Wooster, Ohio
    This was the chain that was throwing dust last weekend. Tried to work on the "hook" and also rounded the rakers. Comments and suggestions welcome (including my pictures suck).
