Building a new smoker
Discussion in 'The Smokehouse' started by fox9988, Jan 18, 2014.
  1. fox9988
    fox9988
    NW Arkansas 72717
    I have 4'-4" of .280 wall pipe for the smokebox and a 19" piece for the firebox.
    I worked on it for 4.5 hrs Fri and got the 4 end caps cut out of 1/4 plate (with a Plasma cutter thank goodness), 3 end caps welded on, firebox and smokebox saddled out and welded together, and the legs welded on it.
    Now its time for the more tedious stuff, probably take another 4.5 hrs to build the hinges for both doors, door stop for SB, latch and damper for the FB door, heat baffle above FB, flat strap around both doors to seal them, grates, shelf and twin smoke stacks.
    And then theres paint.
    Only one before pic so far. Ill post more later.
  2. Grizzly Adam
    Grizzly Adam Guest
    Looking forward to seeing more pics. I will be building one out of an old fuel barrel this spring, going to put the welder I got from Pete to work on it.
  3. Certified106
    Certified106
    In The Hills
    This is gonna be an awesome thread! Make sure you post tons of pics I can't wait to see this!
    BrianK and Grizzly Adam like this.
  4. Daryl
    Daryl
    Sweet.
  5. fox9988
    fox9988
    NW Arkansas 72717
    Dang it.....I meant to take some pics tonight. I got about 18 hrs into it (had the flu, slow go), coming along fine, prob 3 hrs left. It ain't going to win a pageant, but I think it will cook as well as any.:MM: Pics coming......
    Certified106 likes this.
  6. swags
    swags Moderator
  7. fox9988
    fox9988
    NW Arkansas 72717
    Pics by midnight or Im not a real Hoarder. :smoke:
    cwn877 and swags like this.
  8. fox9988
    fox9988
    NW Arkansas 72717
    It's 1:58. I stand corrected :(
    No pics by midnight. But this is the best I can do......
    Chaz likes this.
  9. fox9988
    fox9988
    NW Arkansas 72717
    Lone_Gun, Chaz and WeldrDave like this.
  10. swags
    swags Moderator
    That's looking good, like it. Is that a blower hooked up in the one picture. Hard to see on my phone it's a little dark.
  11. Certified106
    Certified106
    In The Hills
    O yeah, that's looking great! Awesome job
    We're you trying to make a forge out of it with the leaf blower or just burn it out good, lol
  12. fox9988
    fox9988
    NW Arkansas 72717
    Cert, I was burning the stink off:campfire:
  13. fox9988
    fox9988
    NW Arkansas 72717
  14. Smokinpiney
    Smokinpiney
    "South" Jersey
    Nice job! I like the flappers :cool:
    fox9988 likes this.
  15. fox9988
    fox9988
    NW Arkansas 72717
    Yep, blower forge fire. Firebox and smokebox filled with wood. That's what I call a break in fire, if that doesn't break it, all is well.
    All was well.
    Chaz, swags and Woodwidow like this.
  16. swags
    swags Moderator
    Looks good!
  17. WeldrDave
    Real nice Fox! Should be a sweatheart...
  18. lukem
    Stack flaps. Love it.
