Cheap welding machine
Discussion in 'Everything Else (off topic)' started by mattjm1017, Mar 3, 2016.
  1. MasterMech
    And solid ER70-S6 wire is cheaper than flux core by far....
    Eric VW likes this.
  2. schlot
    schlot
    NW Iowa
    I finally tried my hand with my welder. Had the welder for a while but waited to pick up an auto darkening helmet, gloves, etc. I went with a Hobart 125EZ.
    My first shot at a fillet weld....think I need a "little" more practice. :)
    Eric VW and WeldrDave like this.
  3. WeldrDave
    Great start!
    Eric VW and schlot like this.
  4. schlot
    schlot
    NW Iowa
    Thanks man....coming from you I'm energized to go give it another crack.
    Looking at it I was thinking I went a little too fast?
    I know that 125EZ is a low end system, but the one setting switch and self shielded wire makes it simple for a newbie welder like me. :)
    Eric VW likes this.
  5. WeldrDave
    Your splatter isn't bad so slow down a bit! Keep your tip angle 45* into the joint and your direction angle 5 to 15 *, "no more". Try small little circles as you pull your tip and stay no more than a 1/4 to 3/16 away from your work. Don't laugh when I tell you this but, spray your nozzle with pam cooking oil before you weld! It will keep splatter on your tip down to a minimum. Yes, they make a tip coating spray at + $9.00 a can, pam will basically do the same and is better for you if you breath it! Next, practice, practice, practice… :whistle:
  6. Eric VW
    Great advice, WD!
    Didn't know the Pam trick- always used the 'spensive stuff when I used to weld Transformer parts together.....
    NozzleKleen was pretty stinky!
    wildwest and WeldrDave like this.
  7. WeldrDave
    Nozzle kleen is a synthetic base lub/coating and is "REALLY" bad to breath. I welded in hull cavities with a 433 and using Nozzle kleen about killed me. You need good ventilation with it. For the home guy, Pam is all you need!:cool:
    wildwest and Eric VW like this.
  8. mattjm1017
    mattjm1017
    Thanks for the input on that unit but I had to pass on it right now as my wife wants to be a responsible adult and pay off debt before buying new toys:salute::confused::cool::p:picard:Ill keep looking though and Ill get one in here one day.
    Eric VW, WeldrDave and wildwest like this.
  9. schlot
    schlot
    NW Iowa
    Wise choice. I waited 4 years for the same reason. :)
