MS290 starting issue
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Apr 10, 2016.
  1. Kimberly
    Kimberly
    The Kangaroo State
    I ordered new pawls and the saw is not wanting to pull smoothly; I think it is worst now. I tried it with both one and two pawls. I tested before I put the pull cover back on and the pawl(s) were going in and out without any issues. Could it be something else?
  2. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Yup, the flobber-knocker assembly is probably shot. Order a new one...
  3. Mag Craft
    Take the spark plug out and move the flywheel by hand with the starter off and see if it is moving freely. It should only show resistance when you are at the coil and when moving away from the coil. Other wise it should move smoothly.
  4. clemsonfor
    And if it don't pull over like nothing with the plug out and recoil assemble confirmed operational you may have some mechanical issue there like piston gouging out the walls of the cylinder or bearings grinding up.
    What oil ratio are you running? What kind of oil?
    Barcroftb, saskwoodburner and Horkn like this.
  5. Kimberly
    Kimberly
    The Kangaroo State
    I am running it at the 50:1 mix. I was using the little bottles that a member gifted me but ran out and purchased 2cycle oil from WalMart. I made sure to measure properly and add the proper amount of fuel.
    saskwoodburner and clemsonfor like this.
  6. Kimberly
    Kimberly
    The Kangaroo State
    I will take the plug out tomorrow and do the checks outlined.
    clemsonfor likes this.
  7. Kimberly
    Kimberly
    The Kangaroo State
    I hope nothing has happened to The Beast; I really like the saw.
  8. jon1212
    jon1212
    Utah........ugh!
    You may want to just pull the muffler off, and take a peak at the piston and cylinder through the exhaust port. This will give you confirmation of any damage to the exhaust side, and intake side of the top end. Also, while you have the muffler off, take a look at it for carbon build up internally, primarily on the screen.
  9. MasterMech
    Everything looks normal on the clutch side of things? Clutch drum should spin freely with the bar/chain removed.
  10. Mag Craft
    One other thing you might try Kimberly is to take the starter off and take a picture of the starter pulley and the flywheel and someone here might spot something that is not right.
  11. Kimberly
    Kimberly
    The Kangaroo State
    I haven't looked yet but I do have photos I took yesterday. While I mixed 50:1, my friend told me last night that he mixed 40:1. I don't know how many tanks of 40:1 went through the saw. Would 40:1 cause an issue in the MS290?
  12. Kimberly
    Kimberly
    The Kangaroo State
    This is the original pawl and spring thing before I changed them.
  13. jon1212
    jon1212
    Utah........ugh!
    40:1 is what I run in all of my saws, Old and New.......tuned properly, it is cheap insurance in preventing damage.
    Horkn, Barcroftb, clemsonfor and 2 others like this.
  14. Kimberly
    Kimberly
    The Kangaroo State
    I did not have time to work on the saw; having to work on the front brakes of my car; it is no fun being without transport.
    Horkn and clemsonfor like this.
  15. clemsonfor
    no that's better than 50:1!!
    Barcroftb and saskwoodburner like this.
  16. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I still say flobber-knocker. Isn't the first, won't be the last.
  17. saskwoodburner
    saskwoodburner
    Flobber knockers are always breaking at the worst time.
  18. jon1212
    jon1212
    Utah........ugh!
    Excessive strain on the fliberty gibet is the usual cause.
    Horkn, DexterDay, Barcroftb and 3 others like this.
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Usually, that's BS. Flobber knocker damage is ALWAYS caused by fliberty gibet neglect.
  20. Kimberly
    Kimberly
    The Kangaroo State
    I put in new ones; same issue.
    Horkn, Nixon, bushpilot and 2 others like this.
