messy green slime
Discussion in 'Everything Else (off topic)' started by Greenstick, Apr 28, 2016.
  1. Woodwidow
    I always thought it was zinc you used.
  2. Backwoods Savage
    I may have to try that.
    Greenstick and wildwest like this.
  3. Greenstick
    Greenstick
    I think that both of copper and zinc are supposed to work on roof moss.
  4. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I have a copper cupola roof and copper weather vane on my shed. The roof is clear below. I know they sell zinc strips to slide under roof shingles with an exposed edge.
  5. bushpilot
    bushpilot
    Eastern Washington
    I have heard the same, never tried it. Or was it zinc?
    Edit: Wow you guys are quick!
    Edit again: I guess I am slow, you beat me by a couple of hours ...
  6. Greenstick
    Greenstick
    Well I am gonna give it a go. Found a 18" or so chunk of hard copper pipe in the basement and shined it up. cut two chunks about a inch long and tossed one in each bird bath. Then I stumbled across a 5' length of soft copper and plumbed it into the supply line off of the pump in the bath water feature. The rest of the hard copper pipe I plan on setting in the tub bottom. In about a week or two I will fill the tub and see if the experiment works.
    Horkn and wildwest like this.
  7. Greenstick
    Greenstick
    However thinking on it if I remember correctly in the past I don't remember having to scrub the galvanized small tub at the foot of the water feature. Maybe there is something to this anti algae magic.
