Who Do I Trust
Discussion in 'Modern EPA Stoves and Fireplaces' started by KatwillNY, Jan 21, 2014.
  1. KatwillNY
    KatwillNY
    So I went out and got another thermostat for the 30 as the one I have is going on 10 years. I also picked up an IR recently and Im getting three different readings. The widest gap being between the two analogs, on one Im getting 700 and the other in the mid 400s. The IR is 590ish. Im aiming the IR in the same general direction where the analogs are. Has anyone seen this before?
  2. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Are you shooting the IR at a right angle to the surface. If so I would tend to believe that reading. Oops just looked at the picture again, looks like you are shooting at an angle. Might try it straight on and see if that makes a difference.
    Gary
  3. Flamestead
    Flamestead
    Windsor County, VT
    Yes, 3 magnetic and one IR recently, all different. I'm putting my money on the IR.
  4. KatwillNY
    KatwillNY
    Gary, I thought I was shooting pretty straight, but i will try again. thanks for pointing out
  5. MasterMech
    Check them in boiling water. Except the IR that is. On e you know how far off the bimetal units are, then you will know if the IR is correct or not.
    Certified106 likes this.
  6. KatwillNY
    KatwillNY
    Interesting Point master tech. Ill try that.
  7. Backwoods Savage
    We found great differences in the magnetic thermometers especially with rutland. We have 2 that we got from Woodstock Soapstone and they are the most accurate. They are now 7+ years old and this year I found one is off a bit but not bad yet. I'll believe the IR gun first.
  8. Todd
    Todd
    NW WIS
    Thermocouple is probably most accurate, Auber instruments has a nice digital unit for wood stoves with alarms.
  9. milleo
    milleo
    I stuck mine in the oven and it was dead on....
    Backwoods Savage and MasterMech like this.
  10. Gark
    Gark
    SW Michigan
    I tend to believe the IR before any of the three magnetic gadgets we have.
