Concrete Slabs
Discussion in 'Everything Else (off topic)' started by yooperdave, Apr 14, 2016.
  1. ironpony
    ironpony
    Mid Ohio
    My 2 cents. if you want to put foam under the slab it will be a waste with out having a thermal break at the edge of the slab. Where the slab meets the foundation you need a 2 inch thermal break so the slab does not "absorb" cold from the exterior.
    Being you are pouring a structural slab you can not do this, there fore insulating under the slab is moot point. personally I would do the foundation, foam under slab, slab with thermal break, and put in the tubing, minimal at this point , for radiant heat.
    you could then tie it in to your wood heat source and keep the slab warm. 15-20 yards of cold concrete aint warming up in the winter up there.
    Minnesota Marty likes this.
  2. schlot
    schlot
    NW Iowa
    You can get that thermal break by placing the foam board exterior of the slab, but I'm not a fan of this method as it creates an exposure/flashing problem.
  3. eatonpcat
    Personally,I would take the slab edge down to the frost line. Shouldn't cost too much more and you won't have to worry about the slab moving. Something along these lines.
    Viking80, ironpony and schlot like this.
  4. ironpony
    ironpony
    Mid Ohio
    Mag finish, cut control joints, look into a short trench drain, even a single 4 foot piece, in the center to catch debris rather than it falling into the drain directly
  5. ironpony
    ironpony
    Mid Ohio
    I like eatoncats idea too, you could thermal break as schlott stated, I just hate building without a real foundation, where there is extreme cold/heat cycles.
    Elvisss222 and eatonpcat like this.
  6. Matt Fine
    Matt Fine
    New York
    I did mine as a pole barn so no foundation, except for the poles that are all set below the frost line. The 6" concrete floor sits on 2" of foam and has a 2" foam border.
    Minnesota Marty and schlot like this.
  7. yooperdave
    This slab would include a foam border also. Typically 12" down the side and 36" out and away from the slab footing, both below grade.
  8. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    yooperdave,
    We're spending your money like it is government money. lol.
    The foam on the outside and out is very good idea and we have used it many times. To help resolve the covering of the foam on the exterior above grade we went to a local sheet metal shop and had some custom bent stainless steel to cover the foam above grade with a cap that tucks under the siding for a nice water tight fit. It wasn't that bad price wise. And it has been on five years and still looks real good. The are other products that come in 80' rolls. They are like a rolled fiberglass with a gloss finish. The finish is what doesn't appeal to me.
    You'll have a very nice building
    yooperdave and wildwest like this.
  9. savemoney
    My garage was built in 1990 24 x 30, it is a reinforced slab resting on fill some 6 to 12 ft deep. The slab is thinker at the edge, No foam, no plastic, no drains. but again it is way up on deep fill. The whole building is much the way it was when it was built. Nothing has moved about. I do have a few cracks in the concrete, but they haven't changed.
  10. eatonpcat
    Not trying to spend anyones money...do what you think is best for your application!
  11. yooperdave
    Never got that impression.
    wildwest and eatonpcat like this.
  12. eatonpcat
    My comment was based on Minnesota Martys tongue in cheek comment about spending your money.
    wildwest and yooperdave like this.
  13. lukem
    Don't forget to put power and dust collection lines in the floor too. Oh...and plumbing for a sink drain....and a lift pit.
  14. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Not sure if I overstepped here or not. If I offended some by my comment about spending someone else's money... my apologies. It was intended to be a joke that when people ask me if something can be done? My answer is always the same. I tell them that I have a photo in my office with Tom Silva from This Old House that I got at a trade show and the caption at the bottom reads.. " do you know what the four most expensive words in construction?... WHILE WE'RE AT IT.
    Pretty soon we need to say good enough. That was the point I was trying to make.
    papadave, Viking80, schlot and 3 others like this.
  15. yooperdave
    You didn't overstep at all. And I can't see how you would have offended anyone.
    Many good ideas on the replies I received. Yes, I remembered about the PVC feed for the electric although it may be an overhead feed for the garage....haven't decided yet.
    Heck, I'm not even sure about the size or if I should go with stick built of pole building!
  16. eatonpcat
    No offense taken by me...just having some fun!! Sorry fellas, please ignore my comment!
  17. wildwest
    x2 MM!! we all value your experience and input, invaluable!! No worries ok? Just take all the hams here including me and eaton as comedy only;) Remember too that my lil one has proper ear protection for target shooting with her dad because of you! We all know what we can afford for construction projects, but the extra options some of us might just use, No Worries and thanks for the input on our threads!!
    eatonpcat and yooperdave like this.
  18. yooperdave
    I am enjoying all the comments/suggestions on this thread....and considering to consider them. :D
    Thank all of you and please keep them coming!
  19. Eric VW
    Consider this.....
    :thumbs:
  20. Matt Fine
    Matt Fine
    New York
    I built a 32x48 garage/barn a few years ago. It is not insulated or heated but it was built with the plan to someday insulate it to make a usable winter workshop.
    After much research, hemming, hawing, and considering, I decided on a metal pole barn with insulated slab. The pole building was much quicker and cheaper than a full below frost line foundation but is still anchored below the frost line unlike a floating slab.
    The 6" of concrete sits on and is surrounded by 2" of foam. It is fiber reinforced and only has rebar near the doorways. Not a single crack after several years. I put in several PVC conduits through and under the floor to bring in and out electrical, plumbing, gas, and who knows what else.
