Here's what I have been doing - building a woodshed
Discussion in 'The Wood Pile' started by Gpsfool, Apr 7, 2016.
  1. Gpsfool
    Gpsfool
    U.S.A.
    Keep the suggestions coming.
    W/ respect to the floorboards, they are 2x8x8's. I did put in a few floor joists (is that what they are called?) - see attached pic - taken when the front-to-back joist was in and 1/2 of the side to side one was in. The long side-to-side joist also has footers attached to concrete ground pads every 4 feet. Seems solid when I (230lbs) jump up and down on the completed floor.
    I will add a 2x4 board along the underside of the purlin ends to tie them all together. Also I plan to add 2x4 center boards on each end and in the middle so as to simplify stacking.
    Also - good catch on the fact metal roofing should not be in direct contact with Pressure treated lumber - I'll put 30Lb felt paper on first.
    Gpsfool.
  2. yooperdave
    I have no experience with wood shed building. It looks nice!
    What concerns me is if the floor will have enough support or not?
    What are the spans of the floors compared to other member's wood sheds?
    Horkn, Woodsnwoods, raybonz and 3 others like this.
  3. Jon_E
    Jon_E
    Southwestern Vermont
    I know my avatar photo is small and hard to see, but I don't have a floor in mine. It's a bed of wood chips and then pallets on top of that. Some of the pallets have been in there for 4-5 years and just starting to show some decay. Mine is 8' front to back and 16' side to side and facing south as you see it. Metal roof and all the lumber is rough sawn pine off my old sawmill, no PT stuff at all. It sits on concrete blocks about 2" off the ground. No rot in the posts. It's not going to blow over either, although it could theoretically take off like a sail if a strong wind from the south (like 80-100 mph) came through.
  4. Oakman69
    Oakman69
    Mechanicsville
    Shed looks great man got room for the cords that's for sure.. nice job
  5. Oakman69
    Oakman69
    Mechanicsville
    If u put 2 to 3 cords in er that's about 8000 to 12000lbs. Wind can't touch that. Tornado yea but...... 6 tons weight of a f150.
  6. yooperdave
    You gotta buy a lot of truck to get one that heavy!
    That's the weight of 2 or 3 f-150!
  7. Smokinpiney
    Smokinpiney
    "South" Jersey
    After my first year of stacking E/W in my shed i realized n/s was the way to go. Yes you use more end posts but i just screwed them to the floor and roof joists and removed as needed.
  8. Ashwatcher
    Ashwatcher
    West By God Viginia
    This is how I shadow boarded the ends and placed the "stack stops". I loosely throw uglies in between the stacks. image.jpeg image.jpeg image.jpeg image.jpeg
  9. Canadian border VT
    I don't know I go for the over kill theory my deck holds 12 cord. 2 by 10 doubled 16 oc joist hangered are with 2 by 12 tripled at half way point to carry weight. here's a pic of joist above deck... 20150711_141733.jpg
    That's 16 feet high engineered to hold 7000 lbs live weight whirl pool.. the strapping you see if to pit pitch on plastic roofing so so it shedS water..
    but eventually want to build another like ashwatchers
  10. Ashwatcher
    Ashwatcher
    West By God Viginia
    Good looking work there Canadian border VT-can't have enough bracing-it's not overkill, just good sense :yes:
  11. Ashwatcher
    Ashwatcher
    West By God Viginia
    I pulled several oak "uglies" from between that stack during the few cold snaps we had-the expanded metal grating is invaluable and the key-you should seriously consider it-my estimate is it virtually cuts drying time near half-(i.e. oak ready in 12 mos. as opposed to 24)-I will be furnishing fresh split MM readings to support this contention, same for locust and hickory-It's all about air and positioning...
  12. Gpsfool
    Gpsfool
    U.S.A.
    Time for an update - the Woodshed is essentially done - Since last update I have done:
    A> Added bracing
    B> Installed the metal roof panels, used 30lb felt paper between the purlins and the roof panels.
    C> Added additional floor bracing between joists & ground.
    D> Attached the four corners of the shed to 30" long screw-in ground fasteners - this shed is not going anywhere.
    Town is coming over later today to inspect.
    Attached are a few pics - showing the completed shed, details of roof from inside, and 4x4 posts connection to ground screws
    I'm still not sure which way I'll stack wood - n/s or e/w. As I have two 8" bays in this shed I may do both - e/w on one side and n/s on the other. I have some time to experiment.
  13. savemoney
    that's a fancy woodshed. $$$$$$ you should have that one for as long as you want or need it.
  14. Log Dog III
    Log Dog III
    Madison AL
    That's a nice looking shed!!!! :thumbs:I was going to suggest cross-bracing from a lower corner to an upper corner to resist racking however, the corner bracing you just installed should be plenty. You have lots going for this shed: the weight of the structure; the concrete footers for the post; and the tie-downs. It should resist just about any wind load. When the wood is stacked that shed wont be moved by an F5.
  15. yooperdave
    Now to get it filled up!
  16. Eric VW
    Looks great Gpsfool :thumbs:
    You could host a Hoe Down on that before you fill it with farwood!:yes:
  17. HDRock
    Nice job for sure great looking shed :thumbs:, next up :stacke::stacke::stacke:
    Woodsnwoods likes this.
  18. eatonpcat
    Load it up with wood and it's not going anywhere...Looks very nice by the way!!
    Woodsnwoods, Ashwatcher and schlot like this.
  19. bogydave
    Nice & stout !
    Full pictures soon ? :D
    Woodsnwoods, Smokinpiney and papadave like this.
  20. Gpsfool
    Gpsfool
    U.S.A.
    Time for an update - here is a pic taken in August - shed full. Right side is 3 cord 18-24 month old CSS wood for use this winter. Left is 3 cord of newly CSS for burning two years from now. I got another 6 cords stacked in various places in the yard. Good to be three years ahead.
    Gpsfool
