Earth magnet on bar , for 17" rounds
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Jan 16, 2014.
  1. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    How do you cut wood with it attached?
  2. bogydave
    Mostly just walk the log & mark it. Then remove & cut the log to skid-able lengths.
    Sometimes I cut rounds if the size & conditions work out.
    My method of getting wood by felling & skidding logs to the trailer
    a bit different than most.
    Short vid:
    raybonz likes this.
  3. Guido Salvage
    Guido Salvage
    Far too anal for me, I use my chainsaw to cut wood, who cares if one piece is a half inch longer than the next? If someone is that OCD about their firewood length how do they ever deal with the mess it makes in their house?
    Just to clarify, I do not blow dry or wax my saws either...
    raybonz, Osage Orange and DexterDay like this.
  4. DexterDay
    My problem is I can't keep them 1/2" shorter or longer. I will cut one a 22", another at 10", and the next at 15"
    I like to get the most out of the wood eater. So the longer the split, the more efficient my load is.
    I have tried numerous times to just "eye it". Having cut a lot of wood, I thought I would have found he sweet spot?? Nope...
    Horkn and WaddleRemodel like this.
  5. bogydave
    If I could cut to within 1/2 inch of 17" by eye
    I wouldn't use it.
    but I am within 1/2 " using it.
    Anal, yea that's me, me & my stove are pretty finicky & like 17" firewood.
    Before the length measuring bar jig: 15 to 20"
    Now 17" ( they all fit) ;)
    What mess in the house ? Wood chute into the basement wood box near the stove. :)
    Oliver1655, Chvymn99, Horkn and 5 others like this.
  6. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I don't call it anal I call it efficient! If I can fill my box and have as little air space as possible it's worth it to get every bit of heat out of it. Personally I use an old dowel that has a small nail in each end and all I do is set it down cut then set it down again and cut. I may try attaching it to an earth magnet I like that idea Dave!
    Horkn and raybonz like this.
  7. olyman
    olyman
    personally,, i couldnt keep the firewood at a consistent length,,so I used a 2x2 20" long.......I like the magnet idea better, as I wont have to keep moving a 2x2!!!!near dead length,,keeps a much tighter stack in the basement,,with farrrrrrr less air space!!!
    fox9988 likes this.
  8. bogydave
    I used an 8' stick with 17" marks for a while.
    Over time it ended up to short to measure more than one
    at a time. :confused:
    This method has worked well for me
    for 3 + years , for my style of cutting.
    Now it's second nature to put the measuring rod on the bar
    & measure 17". I can carry a spare now.
  9. Osage Orange
    Osage Orange
    Is 17" the correct length for a specific stove or just an accepted standard of some sort?
  10. bogydave
    Fits my stove N/S loaded well.
  11. lukem
    My problem is that when the diameter of a tree goes up, so does the length of my cut if I just eyeball it. I guess it is a ratio thing, but my mind tells me that cutting a 24" round where is "should" be cut is way too short...then I end up with stuff that won't fit in my stove. Happens almost every time. That being said, I still don't mark anything :emb: and have to load it E/W instead of N/S.
    Horkn likes this.
  12. charlie
    charlie
    Schoharie, NY
    Baileys sells this set up..Looks like a double threaded nut that you replace a nut on your side cover and thread in the rod length needed.
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • email product to a friend
      [​IMG][​IMG]
    Quick Stix - Firewood Log Guide
    Average rating:
    Only: $11.99
    Item #: 47150
    In Stock
    Shipping weight 1.94 lbs.
    Qty.
    Tired of your firewood having uneven lengths? Here is the solution! Quick Stix easily mounts to most chainsaws including Stihl, Husqvarna, Echo and Poulan to quickly and efficiently measure out the lengths of your firewood without stopping. One set of stix include 14", 16" and 18" lengths.
    Qty: Item #: 47150
    In Stock
    Horkn likes this.
  13. bogydave
    I saw those after I made the one that fits on the bar.
    Now that I have the magnet one,
    I'm biased toward the type I've been using for 4 years.
    For my process, it works well.
    I've Spoiled myself having my firewood all the same length :)
    Waiting to see how the one Beetlekill is making , works for him.
    He should be getting the magnets soon.
  14. charlie
    charlie
    Schoharie, NY
    I hear ya Dave...Just posted those for people who might no want to drill their bar...
  15. bogydave
    Beetle going to try the earth magnet & no 1/4" hole in his bar.
    Friction of the strong earth magnet should work.
  16. Osage Orange
    Osage Orange
    Help me out - what does E/W and N/S stand for?
  17. bogydave
    Wood loaded N/S (North south) :
    Loaded the other way would be E/W
    HoneyFuzz likes this.
  18. Osage Orange
    Osage Orange
    Got it. Thanks!
  19. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Great idea !! I have seen a few for sale here and there on the net..but none as cool as these !! Good job !!
    I also had a question..as I am thinking of doing this now !! Do the rods get in the way or snag alot..or are they pretty easy to get use to ?
    Did I mention that this is a great idea ?? Beats the 18 inch conduit and log crayon I keep in my chainsaw case !!
    Pallet Pete likes this.
  20. MasterMech
    The safest way to use these is to attach it via magnet or a wing nut, then mark the cuts you want to make on the log. Once the cuts are marked with the saw, you detach the measuring stick and make your cuts normally.
