Receiver Hitch Rust
Discussion in 'Everything Else (off topic)' started by thewoodlands, Mar 14, 2016.
  1. HDRock
    yeah that's what I'm talking about, pull from the side on the wrench or bar on the wrench
  2. rottiman
    Forget the WD-40 on the threads, that will be gone in the blink of a eye. Fluid Film will work a whole lot better and last a whole lot longer. Best bet is some never-seize grease on the threads, just don't get any on your hands. Grease up the threads, install and tighten the nut and then wipe off the excess on the exposed areas.
  3. rottiman
    Remember, go easy if it's on a Ford........................:rofl: :lol: They can't take a lot of abuse...................
    Backwoods Savage and HDRock like this.
  4. thewoodlands
    thewoodlands
    I forgot about the F.F. and I'll have to get some N.S.
  5. thewoodlands
    thewoodlands
    Are they all the same or is one better than the other?
    Advance Auto Parts: Search Results for seize
  6. Matt Fine
    Matt Fine
    New York
  7. rottiman
    thewoodlands likes this.
  8. rottiman
    They work on the light-weight stuff, but repeated heavy trailers with heavy weight and the ball connector pin gets sloppy because the hole elogogates.
  9. thewoodlands
    thewoodlands
    If our bread comes out good, I'll be making my father some so I'll pick it up when I go see him.
  10. rottiman
    Fluid Filming the inside of your receiver tube works a whole lot better than greasing it. Grease picks up and holds a lot of grit which tends to seize up the hitch tube inside the receiver tube. The other great thing about fluid film is that since it is lanolin based vs. petroleum based, you can spray a little on your hands to prevent those dry, winter skin cracks that your hands develop.
    Backwoods Savage and yooperdave like this.
  11. Backwoods Savage
    And if the bread doesn't turn out good, you won't go? You'll be baking more?
    papadave and thewoodlands like this.
  12. thewoodlands
    thewoodlands
    Maybe I'll take him those Hot Cherry Peppers with the bread, sure would cool things down here, ouch!
    papadave and Backwoods Savage like this.
  13. MasterMech
    Just for anybody else reading this thread, an air hammer (with flat face hammer bit in) can work wonders with this stuff. Tie/chain the hitch to something immobile, have the wife sit in the truck with it in D, (if you have three pedals you're gonna have to get a bit more creative) while you put a whole bunch of vibration to the hitch. Those millions of little blows can do a lot more work than a few big hits.
    thewoodlands if you really want that ball off the mount, you might be able to cut it off with a cut-off wheel on an angle grinder. Even if you can only get part way through the shank, pound it off with a hammer/chisel.
  14. triptester
    triptester
    S.E.Wisc.
    The best method to keep the hitch from rusting in place is to remove it when not in use.
    Matt Fine and MikeSs like this.
  15. Matt Fine
    Matt Fine
    New York
    I am not towing anything over 7,000 lbs and nothing on a regular basis, so it works for me. If you are towing that often and need different ball sizes (seems like most daily towers would use the same ball), spend the small amount of money it costs to have a couple different mounts with the ball "permanently" attached. I can't see wanting to unbolt the balls on a regular basis. The mounts are in the price range of a couple fast food lunches, not worth skimping on if your time is worth anything.
  16. eatonpcat
  17. concretegrazer
    concretegrazer
    Southwest MO
    I've had some froze so much that a 1" impact with it heated wouldn't break free. Sometimes you just have to cut them off & move on.
  18. concretegrazer
    concretegrazer
    Southwest MO
    eatonpcat likes this.
