look what I have done
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Charles Ingalls, Mar 22, 2016.
  1. peterfield
    peterfield
    She said the same thing.
  2. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    :rofl: :lol: This thread just got hilarious
  3. will711
    will711
    Pocono Mts.
    I got to think about this one :smoke: It might be a tie :thumbs:
  4. jtakeman
  5. CleanFire
    CleanFire
    Here is LordZ, waiting for the Harman install ..
  6. savemoney
    Let the stove do its work, and you will find it runs along very well on most any pellet. I found running in on the thermostat at room temp caused the stove to cycle on and off a lot, but that also cause a lot of hot initial fires that burn clean. I can always see through the glass, not clean but I can see into the fire. When I open it up and do a brush and vac about once a month, the normal speed bump in the fire pot is just a little and very brittle. If I run on stove temp. It run on low and more dirty. I have the p68 and it wants to crank out the heat. Doesn't seem to mind what I feed it. I got a lot of advice to switch out stoves every time I kept complaining about this and that with my other stove. The price scared me. Finally, I made the jump. Happy every day for that move.
  7. jtakeman
    ivanhoe, CleanFire and IHATEPROPANE like this.
  8. eatonpcat
    Way!!
    ivanhoe, will711, CleanFire and 3 others like this.
  9. artc
    artc
    Rocky Hill, CT
    i just cannot 'like' that. its just wrong:rofl: :lol::picard: there's more i could add to that, but then this thread might go over the edge....
    CleanFire, bogieb, ttdberg and 2 others like this.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    So true :whistle:
