What are y'all working on today?
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Mar 7, 2015.
  1. clemsonfor
    All back together minus the plastic cover.
    I also thought about it and the rear O2 upstream sensor had a bad heater in it for like 4 years so I went this mourning and got it to replace while the manifold was off and its easy to get from the top side. IMG_20160103_161907_977.jpg
  2. Horkn
    I got my garage all cleaned up and re organized. Plus I won the final $100 in my fantasy football league at work. I won $350 between last week and this week.
    Nice huh? Here's my grandpa's old stihl top handle. I'll give her a rip tomorrow and see if she starts. IMG_20160103_190236988.jpg
    If she goes, I'll see how sharp the chain is and cut a few of my long pieces of wood down to 17", or maybe just in half to make it easy. Most of the long pieces are 22-24"
  3. clemsonfor
    I think scotty has a bunch of those!
    I have endended up with three 009 saws. One I bought flipped and ended back up with bit when it was loaned and destroyed. Uses it as a parts unit to fix mine I use. I still have one in a case that I need to fix. I got it for like $25. Gonna use the parts saw to fix the other one.
    Horkn and Bert like this.
  4. Bert
    Bert
    Out west.
    Changed the oil in my new to me Ford F250 4x4:banana: also changed oil and air filter in my Toyota Corolla. Just a bit cold in the garage 22f with the door open. :shiver:
  5. Barcroftb
    Barcroftb
    The Mitten
    That's a beaut! They don't make em like that anymore.
    Horkn and clemsonfor like this.
  6. Deererainman
    Deererainman
    Union City Ky
    Cleaned up some saws, sharpened some chains and played with the 288xp today. See how filthy they are.
  7. clemsonfor
    Looks like a nice black locust round to me. Maybe honey??
  8. Deererainman
    Deererainman
    Union City Ky
    Hedge Apple... My favorite.
    concretegrazer, Barcroftb and Horkn like this.
  9. Barcroftb
    Barcroftb
    The Mitten
  10. Nixon
    Nixon
    West Sunbury,Pa .
    Just got an 029 Super back together and running . Got it free with a smoked piston worn out bar ,chain ,and sprocket ,leaking fuel and oil ,completely clogged air filter ,trashed muffler ,and a few other things . It is now a 039/390 ,all new lines filters ,b&c (.325 nk 8t sprocket ) ,and whatever else it needed . Turns 13,200 at a slightly fat tune . Painted it black / forest green NATO colors ,then a couple of coats of polyurethane . Pics in a bit . Gonna go play with it .
  11. UncleJoe
    UncleJoe
    SC Pa
    The carb on my daily use 200T started acting up on Monday. So this morning before I went to work I pulled one off one of the other 200's that is leaking oil and swapped them out. Runs like a champ again.
    Sorry. No pics. It was 5:30 and I was just barely awake.
    Barcroftb and clemsonfor like this.
  12. clemsonfor
    Yet you were working on saws! You sir are eat up with it.
    Barcroftb likes this.
  13. TurboDiesel
    so ...you work on saws in your sleep...:whistle:
  14. UncleJoe
    UncleJoe
    SC Pa
    Almost. The sun wasn't even up yet. :sleeping:
    clemsonfor and TurboDiesel like this.
  15. Nixon
    Nixon
    West Sunbury,Pa .
    Pics of the 029/390,as promised .As you can see it was somewhat worn out and neglected . Didn't do pics of the original plastics but they were rough .
  16. TurboDiesel
    Todays project
    Cleaning up Ruger's hoard. He cannot go out without bringing back a stick
    Yes, thats a bucket and the scabbard for my saw:doh:
    Ruger getting ready for a campfire...getting the teepee started :picard:
    Yes everything in this wagon was brought in by the dog:hair:
    He is addicted to wood...I don't know where he got that from :whistle:
    Bert, Horkn, mike bayerl and 5 others like this.
  17. clemsonfor
    Is that drywall screw in a pic what you used to pull the limiters?
    They changed angle of the outlet on that exhaust diverter shield on those aftermarket mufflers.
    Horkn likes this.
  18. Nixon
    Nixon
    West Sunbury,Pa .
    Yep that's what I used . As to the muffler ,yes it's got a different angle on the diverter than the 029 had . But, I've seen the angled diverter on newr 1127 saws . It and the muffler are also opened up a bit to let the evil spirits escape quicker as well .
  19. A Visitor
    A Visitor
    Decided to replace the carb on a 028av Super that was given to me. Original owner had it about 25 years and got tired of the blood letting he gets from the local dealer on annual tune ups. Eventually they gave him the "better to just get a new saw" talk and sold him a Homeowner line saw- I think a 211.
    I put a piston and rings in it , but could have gotten away with just rings. Carb was finicky, needed adjustments about every time out. Drive sprocket was badly worn so I did a rim sprocket conversion. After a new bar I decided it was time to go all in. I haven't had much luck with rebuilding so I bought a replacement carb. Starts and runs like a charm- hope to get some cutting done this week.[​IMG]
    Horkn, 94BULLITT, cnice_37 and 4 others like this.
  20. Mag Craft
    I have a Husqvarna K960 cut off saw that I tore down back in November 2015 and installed a new crank shaft, new bearings and seals. Also put new rings on it while tore down.
    Then that is as far as I got until today. I put the cylinder back on and got it all put back together. Saw starts, runs and idles good. I just need a diamond blade for it now to cut some concrete.
    It took more time to clean all the parts then it did to put them back on.
    JeffGu, A Visitor, Nixon and 3 others like this.
