Noodling - a How-to
Discussion in 'The Wood Pile' started by Shawn Curry, Mar 20, 2016.
  1. Shawn Curry
    Shawn Curry
    Western NY
    You may have heard the term "noodling". This technique can be used to cut large rounds down to a more manageable size. The saw is oriented parallel to the long grain of the wood, and sawn this way the chips end up in long strands or "noodles".
    This technique places an intense load on the saw, so select the most powerful chainsaw available. The round is laid on its side, and the cut is made top to bottom lengthwise.
    Sometimes the noodles can start to jam up behind the clutch cover, especially if your saw has an outboard clutch or narrow cover. Varying the pitch of the saw cut will produce shorter noodles that clear easier.
    To avoid dragging your chains through the dirt, an axe or wedges can be used to finish the job.
    Armbru84, Deadwood, milleo and 38 others like this.
  2. bushpilot
    bushpilot
    Eastern Washington
  3. Gark
    Gark
    SW Michigan
    Wowsa! How long is that bar & chain ?
  4. Shawn Curry
    Shawn Curry
    Western NY
    Its a 60" bar, 172DL chain - 404 full chisel skip sequence.
  5. bearverine
    bearverine
    Winchester, Indiana
  6. thistle
    thistle
    Polk/Guthrie Counties,IA
    LOL I was noodling 30 years before I heard the term.....;)
    I solved the jamming problem on my Mac 125C by swapping out the original clutch cover for one I modified.
    The 125 has more power than any stock saw sold in the past 40+ years,chips/noodles will really pile up fast.
    Didn't want to destroy the original one so I located a cheap slightly battered one from one of my West Coast contacts...:D
    All that mattered is that the bar stud holes were intact & hold securely.
    Deadwood, milleo, Barcroftb and 15 others like this.
  7. Babaganoosh
    Babaganoosh
    Jersey Shore
    I don't usually go full noodle. I'll put a notch in it and then a wedge and a sledge. Couple shots and it's split.
  8. redneckdan
    redneckdan
    Northern Minnesota
    I find that my inboard clutch 576 packs up much worse than my outboards 395 did. The stock 576 clutch does have ventilation ports, an unvented clutch might not have as much issue. The 576 is able to pull 24" full comp 73LGX with an 8 pin sprocket in the Norway pine that are predominantly the large trees I deal with.
  9. thistle
    thistle
    :dex:
    I wouldn't advise wearing headphones while watching this video....:D
    Disclaimer - Video filmed Oct. 2014.Reason that nasty black stuff is on the bar at beginning of video is I'd run out of my usual canola/soybean/salad oil a couple days earlier,hadnt bought a new jug yet.So I found some old oil in a jug behind my shed to use for a couple cuts.Immediately afterwards the oil tank was flushed out twice,new oil added..Also at end of video where I'm a bit disgusted while looking for something - At least 1 of the nut/bolts holding the inner spike on had vibrated loose,it was lost in the shavings someplace....:hair: The next day I went to neighborhood hardware store & replaced all SIX of those nuts with nylon insert lock nuts.Three nuts/bolts for each spike. Now no matter how much heavy use,NOTHING works loose. :yes:
  10. Eric VW
    Laying down on the job, huh Shawn Curry :rofl: :lol:
    Nice write up, bud:thumbs:
    Great :ithappened:
    Sweet :saw:
  11. Backwoods Savage
    Shawn, those pictures are keepers! Judy really likes the one with you laying down on the job. I called her over to the computer and she said, "Hey! That's Shawn!" Yes, she remembers you.
  12. basod
    basod
    Mount Cheaha AL
    Awesome Shawn:thumbs:
    I made an open "clutch cover" from a 2x4x1/4" blank of aluminum plate specifically to noodle.
    You just need bar stud holes, and an additional hole for newer side tensioners, all edges chamfered with a hand file. It works like a champ but if your saw needs extra supporting structure find a beat clutch cover and follow thistle lead
  13. Eric VW
    Do you have a pic or a link concerning this mythical Aluminium plate?
    Barcroftb and Shawn Curry like this.
  14. lukem
    We're not in England. 'Merica.
    thistle, Barcroftb, cnice_37 and 3 others like this.
  15. Eric VW
    You so right... Bit of the "did that on purpose" thing going on right there.
    :usa:
  16. Knothead
    Knothead
    East Texas
    :saw: That saw looks like its on steroids!
  17. DaveGunter
    DaveGunter
    With a side of Viagra!
    milleo, Drvn4wood, Oldman47 and 6 others like this.
  18. trktrd
    trktrd
    Arkansas
    Are you fuelin' that saw with the stuff in that Mason jar ?
  19. Lumber-Jack
    Lumber-Jack
    Looks to me like somebody may be over compensating for something. :whistle:
    milleo, Drvn4wood, unclefess and 2 others like this.
  20. Shawn Curry
    Shawn Curry
    Western NY
    It's true.... :emb: My pile of black walnut slabs is smaller than I'd like it to be. But I'm working on it... :)
    These ones are about 50" wide.
    milleo, Drvn4wood, DaveGunter and 4 others like this.
