Nc30 questions
Discussion in 'Modern EPA Stoves and Fireplaces' started by Ruffrider, Mar 16, 2016.
  1. Babaganoosh
    Babaganoosh
    Jersey Shore
    I'd say it's a combo of wet wood and marginal draft. That chimney needs an insulated liner, or a liner at the very least.
    Well I said that originally but after your pics and description I'm almost positive.
    Eric VW likes this.
  2. yooperdave
    I would think the stove glass should stay cleaner than a week, even though it is a light glaze.
    Eric VW likes this.
  3. Ruffrider
    Ruffrider
    Here is some loaded
  4. Ruffrider
    Ruffrider
    There is a liner in it.
  5. yooperdave
    Often times, we fall into the trap of only looking for one solution to a problem when it fact there may be more than one contributing to a given problem.
    The easiest would be to try some dry wood, no?
    Eric VW likes this.
  6. yooperdave
    I just bought a nc-30 so the next question I ask is out of ignorance.....but is the discoloration around the bottom of the stove opening indicative of needing a new door gasket? Or maybe a gasket that is beginning to weaken?
    Eric VW likes this.
  7. Ruffrider
    Ruffrider
    Okay 32 blocks 8" a block equals just over 21' of chimney just measured it.
    Eric VW likes this.
  8. Babaganoosh
    Babaganoosh
    Jersey Shore
    I don't have a 30 so I'm not sure what else it could be. Only other thing I can think of is not giving it enough air.
    CenterTree, yooperdave and Eric VW like this.
  9. brenndatomu
    Like a (ovalized) stainless liner? 21' of that should work fine.
    If there was a draft issue, swapping that 90* elbow out for two 45s would help. You would put the first 45 about where you have the mag thermometer in that pic, then about 2-3' of pipe, to the second 45 around halfway back on the horizontal pipe...just for example
    papadave and Eric VW like this.
  10. HDRock
  11. Locust Post
    Sorry I got called away for some pressing issues with my elderly mother. It sounds like you guys worked through this or gave some good suggestions. My guess is the wood is not seasoned enough. If it wasn't split until Aug. there is no way especially if it is something like oak.
  12. papadave
    I forgot my manners....Welcome aboard Ruffrider .
    With the 2 90s, you've lost at least a few feet of flue length, although I don't think that's your issue.
    If you need to keep the air open that much, your draft may be weak, and/or the wood isn't dry. Wood doesn't start drying well until it's been split. Sittin' around in log frm or rounds, they'll take a LOOOng time to dry well. Unless of course, you live in a desert.
    I'm seeing signs of overfire in the front of the stove just inside the door.......This is what it should look like, and yours looks warped......I can see fire through the gap.
    Here's where I usually set the air on an overnight burn. The rod is about in the middle of the spring.
    Chvymn99, yooperdave, Eric VW and 3 others like this.
  13. HDRock
    Wow, I didn't notice that, it sure is warped.
  14. Ruffrider
    Ruffrider
    Well the weld broke on the left side and the right side warped. Honestly no offense to anyone I love this stove and I hate this stove. It is so hard to figure out. I never ran an EPA stove. First one was a hearthstone h1 and the second one was an Ashley wood circulator.
    Eric VW, wildwest and HDRock like this.
  15. Ruffrider
    Ruffrider
    Warpage
    Eric VW likes this.
  16. Ruffrider
    Ruffrider
    Pretty sure that piece is there for decoration, I think I'll be angle grinding the remaining two welds off and pulling that off and out. People say overfire but I read on this site 750 is the norm and that number scares me. And that stove runs there. I see pics on here of the stove loaded to the tubes on top and I just don't get it. How am I overfiring if I am closing down the air too much making unburnt wood in the back of the stove?
    Eric VW likes this.
  17. wildwest
    We have run 3 smoke dragons and one defunct cat stove in the past 25 years, right now I have a small version of your stove, its an insert. Like you said, different animal to run, I am still not used to one control for air intake. Dear Husband likes to load the new tiny insert too full and it raises the baffle which blocks the flue heating/draft. Not intentionally, he's just not used to the much smaller firebox yet , and also makes it harder to warm the chimney up for the draft than our pre epa stoves. It's a tradeoff? Sorry to say, I noticed the front edge warped too, no idea how that affects burn, but...
  18. Eric VW
    Sounds like he's trying to accommodate a makeshift "bypass" by pushing up the baffle....:rofl: :lol::thumbs:
  19. papadave
    If that metal is warped like that, it's been overfired, no matter what the thermometer says.
    There's nothing on this stove for decoration, unless yours came with the little gold-ish colored strips along the front lips.
    I usually run mine about 500-550, although it sometimes gets up to 700, if I forget there's a fire in the stove.
    This stove is very easy to run with dry wood.
    After thinking on this, I don't think you are closing the air too much (based on the pic you posted), rather the wood isn't dry enough.
    When do you start closing the air?
    Chvymn99 and Eric VW like this.
  20. wildwest
    :sherlock:
    Eric VW and papadave like this.
