Conversion for Oil Burner?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by MtDew, Mar 7, 2016.
  1. MtDew
    MtDew
    Perkasie, PA
    ivanhoe likes this.
  2. imacman
    imacman
    Denver, NC
    Good question.
    ivanhoe likes this.
  3. jtakeman
    Quote from the site. Renovator - WoodMaster
    Oops: See burner PDF
    I also attached the brochure.
    ivanhoe likes this.
  4. Lousyweather
    Lousyweather
    First of all, that's a boiler.
    I wonder about the heat output and how it's calculated....seems a bit small for houses in a cooler climate. And given the cost of oil, its simply cheaper right now to burn oil.......
    ivanhoe and jtakeman like this.
  5. don2222
    don2222
    Salem NH
    Yes
    Also it seems to take a lot of pellets to heat a forced hot water system. I have a residential PB105 that I clean once a year but it consumes about 10 tons per year of pellets. Also from my experience the Harman pellet boiler is the very best and very well designed to burn pellets and heat water with it's enormous heat exchangers and very large hopper but never seem to have caught on and there is not many around.
    Converting something that is not totally designed to burn wood pellets may not be as easy to clean and maintain or be as efficient extracting the pellet heat.
    ivanhoe, bogieb and subsailor like this.
  6. bogieb
    Was looking at pellet boiler before getting the P61. Would have loved it but short basement and no place to put a bulk feeder kind of shot that down. State would have paid for 1/3 of price (assuming "approved", then got the paperwork correct), but I just couldn't figure a way to do it with my house.
    gbreda, ivanhoe and jtakeman like this.
  7. don2222
    don2222
    Salem NH
    A pellet boiler also heats DHW too which is nice but in our area the electric rates are fairly low and the ECO Smart instant hot water panel is inexpensive. So I just put in a 125 amp sub panel next to the Super-Stor so an EcoSmart 18 would be easy to pop in.
    Luckily the tap water mineral content is very low.
    See my neighbor's install.
    ECO Smart ECO-18 Instant & Efficient Electric Hot Water System Installation pics-Good & Efficient??? | Firewood Hoarders Club
    Adding an array of solar panels could then give free hot water. :)
    See New panel pic below:
    bogieb likes this.
  8. jtakeman
    A friend of mine has a buddy with a boiler conversion in NH. From what he states its a pellet hog and a tight 1600 sqft ranch house. used almost 10 tons last season and almost 8 the season before. He's used 6 so far this season. Its also doing all his hot water IIRC. His previous worst season with oil was 875 gallons. Approx 11.6 tons using the 1.5 gallons per bag rate(not sure how accurate that is??).. Not sure that worked in his favor with the price of oil this season. $249/ton compared to $1.80 a gallon..........
    Tough for me to by in as I haven't used 5 tons even last season with a bigger shack thats kind of loose compared to his. Granted my climate is milder, But its not 5 tons worth milder. Nor would I expect to use that much tonnage to heat the hot water. Anyway, Here a couple a pics of his install!!
    bogieb likes this.
  9. Lousyweather
    Lousyweather
    and since Harman no longer makes them, a non-issue
  10. jtakeman
    Seems many have dumped their pellet furnace's.......
    Sad they didn't catch on, Specially the ones that can be sistered to an existing oil/gas/propane unit.
    bogieb likes this.
