Insulation
Discussion in 'The DIY Room' started by mattjm1017, Feb 21, 2016.
  1. mattjm1017
    mattjm1017
    I fear you may have me confused with someone else? I have had the Fireview since 2012. We just havent been using it much this winter becuase of warmer weather and my school/work schedule have prevented my from messing with it (aka Ive been lazy and have been letting the heat pump run but its pretty darn efficient and our electric bill hasnt been to much higher than normal):tears:
    Eric VW likes this.
  2. mattjm1017
    mattjm1017
    In these two pictures would it be ok to just fill in the small to medium areas around and under the windows with that canned foam stuff instead of cutting insulation to fit?
    Eric VW likes this.
  3. schlot
    schlot
    NW Iowa
    That would work fine. Just make sure you use the low expansion foam meant for windows.
  4. papadave
    Matt, I did that in a couple narrow stud bays, but it takes quite a lot so buy a bunch of cans. At close to $7/can, it can add up pretty quick.
    I did one bay floor to ceiling that would have been a major PITA to use batts, due to the way the wiring was done there. It was only about 4-5" wide.
    In the 1st pic, I'd use batts, but you could foam the small bays in the 2nd pic.
    Be aware that you don't want to try filling the whole cavity at once. It'll take about 2-4 layers to do it. If you do too much, it'll just sag and puddle out.......ask me how I know.:headbang:
    Between the window frame and the wall framing, definitely use the window/door stufff.
    Eric VW and mattjm1017 like this.
  5. Canadian border VT
    matt, if you want home Depot sells the pro gun for like 40 bucks.. comes with a cleaner and a can.. I hate those disposable cans cause one the plastic tip drys you can't buy more tips. end up having 2 or 3 partial cans and no way to use it!
  6. papadave
    That's a good idea CbVT, especially if you ever plan to do more foaming.
    I threw out a couple not quite used up cans, although I was able to unclog a nozzle on another and finish using it up.
    Eric VW and Canadian border VT like this.
  7. schlot
    schlot
    NW Iowa
    Wow! $7 a can? I just picked up 4 cans for $2.50 each at Walmart this week.
    Eric VW, papadave and mattjm1017 like this.
  8. yooperdave
    Big plus on the non-expanding foam for windows and doors. Another thing, make sure you don't ever want to change out the windows and doors once you spray foam the cracks!!!
  9. mattjm1017
    mattjm1017
    Yeah I intend to use batts in all of the cavities except like you said the small bays under the window in the second picture.
    We would like to replace all of the windows in the house next year if I spray foam the cracks around these windows would that make it a major PITA or impossible to do in the future?
    Eric VW likes this.
  10. yooperdave
    It would not be impossible but ......
    If you're replacing windows so short time away, just use the fiberglass for now.
    The spray foam I've used is also an excellent adhesive!
  11. mattjm1017
    mattjm1017
    The plan is to get them all replaced next year hopefully that will work out. Ill keep your advice in mind and avoid foam around the windows. Thanks for the heads up:yes::handshake:
    Eric VW likes this.
  12. JustWood
    JustWood Guest
    It would be hard to convince me to not ad any insulation as long as those walls are already open. But that's me.
    Eric VW and papadave like this.
  13. papadave
    A Sawzall would make short work of any foam. Just run the saw around the window/door frame. It'll require some foam scraping, but I HATE using fiberglass around doors and windows. It invariably allows air in.
  14. yooperdave
    Very true. The fiberglass finally ends up acting more like an air filter more than anything. But using it sure makes for easier removal with little to no damage to old windows...making them easier to get rid off (re-sell, donate, etc)
  15. Canadian border VT
    Very true! then most use plastic as a vapor barrier and expect it to stop wind and then puncture it with staples.. effectively making it a screen instead which are great for not stopping wind or water. :hair: but that's my pet peeve with building codes
    Eric VW likes this.
  16. schlot
    schlot
    NW Iowa
    I suppose you can tape over the staples if you are worried about that.
    Never been too concerned myself about the staples as the drywall screws make bigger holes. :)
  17. schlot
    schlot
    NW Iowa
    Youre 100% right. The cans can be a big waste. I end up making sure I have plenty of areas I want to foam before opening up a can. Once you start using it you might as well use it all. I've never had good luck in using a can a second time. :)
    Eric VW, mattjm1017 and yooperdave like this.
  18. mattjm1017
    mattjm1017
    Oh yeah I know what you mean Ive thrown away more 1/4-1/2 full cans than I can count. I have had some success with cleaning the nozzles and being able to reuse them at a later date but that has been extremely minimal.
    Eric VW, papadave and schlot like this.
  19. mattjm1017
    mattjm1017
    Were going to tear out the old insulation today and try to get started on the install of the new.
  20. mattjm1017
    mattjm1017
    Got the new stuff in still need to staple most of it and put in the foam around the Windows.
