550 xp air filters
Discussion in 'Chainsaws and Power Equipment' started by tamarack, Feb 14, 2016.
  1. tamarack
    tamarack
    paulina oregon
    Are there any aftermarket 550xp air filters available? I just kinda think the factory one that came on my saw looks look its not gona do well. Seems pretty thin, i like the filter setup on my 372 alot better.
  2. Gunn
    Gunn
    Plover, Wi
    check with your dealer, they usually have flocked material filters too.
    concretegrazer likes this.
  3. Certified106
    Certified106
    In The Hills
    I don't disagree with you and I have a 550XP......... I have seen this highly debated but have never really come to the conclusion that it is an issue yet. I guess when I figure it out it will be to late :popcorn:
    HoneyFuzz likes this.
  4. tamarack
    tamarack
    paulina oregon
    So the dealers have flocked type filters? The dealer where i live is kinda new to saws, really nice guy but my last visit there he didnt have any .325 chain. So i will ask him 2moro
  5. Gunn
    Gunn
    Plover, Wi
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Did quite a bit of cutting with a 550xp I had. Never had a problem with the air filter. In fact..after a full day of cutting..there would only be a chip or two in the whole air filter area !
    Keep your chains sharp. Make chips..not dust ;)
    crzybowhntr and Certified106 like this.
  7. Certified106
    Certified106
    In The Hills
    Honestly I tear my saw down and clean it up after almost every cutting session and in all of those times with both a 555 and a 550XP I have yet to see any evidence that I have stuff getting through the filters. If I cut a lot in dry dusty conditions or I wasn't on top of keeping a chain sharp (lots of other problems caused by that) I would be a lot more concerned about it than I am.
    Oldman47 and HoneyFuzz like this.
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    X2 ! I was the same way with the 545 and 550xp. They got cleaned after everyday . Which meant not alot to clean out of the airbox :)
    Certified106 likes this.
  9. tamarack
    tamarack
    paulina oregon
    Thank you guys for the info and the part number for the flocked filter, very helpful it seems like the nylon filter is meebe a little better than im giving it credit for.
  10. Certified106
    Certified106
    In The Hills
    Great info right there I may have to order one for a trial! Thanks
  11. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I wouldn't worry about it much ! Just keep the filter and surrounding area clean ...sharp chain....go have some fun !
    But if the other filter makes you sleep better..than go for it :thumbs:
  12. Gunn
    Gunn
    Plover, Wi
    I've run the yellow mesh filter in my 346 for years I haven't seen any fines get past the filter into the intake. They seem to work good enough.
    DexterDay, Certified106, RCBS and 2 others like this.
  13. concretegrazer
    concretegrazer
    Southwest MO
    I've ran them both & couldn't tell the difference. The flocked is harder to clean. They say to run the nylon if you're having trouble with icing.
  14. RCBS
    I ran em on my 350 for a decade and the boot was always clean.
  15. bassJAM
    bassJAM
    Cincinnati, OH
    As others have said my 550 is always pretty clean around the filter area. I'm guessing I remember to clean it every 4-5 tanks.
  16. RCBS
    My 550 actually came with the flocked filter, but due to seeing fines in the intake boot, I switched to the nylon. Not enough cutting time yet to see if there is a difference.
  17. Gunn
    Gunn
    Plover, Wi
    The flocked should filter better than the mesh. Did you try the oring mod or try some grease on the intake?
  18. RCBS
    I know. That's why it was concerning to see the fines. I have not modified anything yet. I have been playing this same game with my 2166, which came with flocked and also had some fines getting by. Wish the weather would get better so I can continue my "research". :D
  19. tamarack
    tamarack
    paulina oregon
    I havent cut very much wood with my 550 meebe a cord or so. I am gona try some grease on the intake. From what several here have said the nylon filter is ok.
  20. Gunn
    Gunn
    Plover, Wi
    I haven't noticed any issues with my yellow Mesh filter.
