Husqvarna 350 Rebuild
Discussion in 'Chainsaws and Power Equipment' started by HoneyFuzz, Jan 19, 2016.
  1. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I hear you..I heard it was a pain..and I believe it. That's why I bought new bearings and seals. But I tell ya...it took some effort just to get the seals onto the new bearings lol !!
    Stinny likes this.
  2. pantelis
    pantelis
    Europe
    Wrong loctite , use red hold better :whistle::D
    HoneyFuzz likes this.
  3. RCBS
    oooh! You have a fancy piston ring compressor! I almost bought one, but ended up just using a zip tie...worked surprisingly well! I orientated the crank to bottom dead center and found that I did not need a piston support. Almost got goop on stuff I did not want it on trying to hold onto everything at the same time and coax the jug down onto the piston though.
  4. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Anybody have a clear answer for this dilema ?? Are you suppose to but sealer in the bearing seal grooves ? For me..this was a pretty tight fit....and didn't seem to be any sealant in those areas on the old parts.... IMG_20160126_131335862.jpg
    pantelis likes this.
  5. pantelis
    pantelis
    Europe
    You dont have nothing to loose if you put a little sealer there , and dont forget METAL clamp to the intake
    Fishnuts2 and HoneyFuzz like this.
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Yes sir !
  7. pantelis
    pantelis
    Europe
    Very good boy
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
  9. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    So I just tore it back apart...and resealed everything....I should have just done it the first time. What a pain lol !
    Stinny likes this.
  10. old 040
    old 040
    Buckeye State
    Bet you slept better last night!.................:sleeping:
  11. Stinny
    Doing a good job of getting that back together HoneyFuzz ... looks like you've even put the right parts back in the right place... how does that happen... :whistle: ... WTG... :yes:
  12. cus_deluxe
    cus_deluxe
    Northern Michigan
    i recently did two 345's and i did put a very thin coat on both top and bottom seal surfaces, whether thats right or wrong i guess ill find out haha.
  13. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I'm gonna find out too I guess lol !!!
  14. cus_deluxe
    cus_deluxe
    Northern Michigan
    the one thing that got me on the first 345 i did was the little brass grounding clip that goes into a slot BEFORE you put the clamshell bolt on that corner.... thankfully i realized it before i got too much farther :picard:
    HoneyFuzz and Oldman47 like this.
  15. old 040
    old 040
    Buckeye State
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Giving me a hard time ? :rofl: :lol:
    Haven't touched this bad boy...but thanks to J.Walker......I have a brand spanking new clutch cover sticker :). No charge ! I owe you one :) IMG_20160212_113906205.jpg
    old 040 likes this.
  17. old 040
    old 040
    Buckeye State
    Was just a wonder'n how this project is a come'n along.........:)
  18. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    It's not...a shinny 488 is kicking my tail at the moment !
    old 040 likes this.
  19. old 040
    old 040
    Buckeye State
    A likely story!!..........:D
  20. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    0-2 on the Shinnys :(
