How do I tune this saw?
Discussion in 'Chainsaws and Power Equipment' started by bobdog2o02, Jan 26, 2016.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I consider welding a hobby, I learned to weld sheet with Flux core on my old jeep xj. Floors were toast. I cut shaped and welded it back together. .. wasnt pretty but it was solid.
    Horkn and clemsonfor like this.
  2. clemsonfor
    I need to weld some sheet into the floors of my old truck. One day.
    Maybe not. As long as it does not get worse I won't mess with it.
    bobdog2o02 and Horkn like this.
  3. clemsonfor
    99% of the time its under a shed so wherever the water is coming from is not going to wet the floor...that is if I havent fixed the leak?
    Horkn and bobdog2o02 like this.
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    All done with the muff in head ler muffer... So i saw they had blue header paint at pepboys, i couldnt resist. i usually see all the city cars with all kinds of dumb colors and just think its distasteful. But being blue saw i thought what the hell.....
    XXL, Horkn, RCBS and 1 other person like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    does it look fast yet?
  6. Barcroftb
    Barcroftb
    The Mitten
    Wait there's a saw in that picture? Sorry got distracted there for a sec. That paint alone has to be good for at least .25 hp! Looks pretty cool!
    Horkn, clemsonfor and bobdog2o02 like this.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I think your seeing part of the AustinPowers Femmebots. It was a white elepant party thing. I tried to ditch it for the next 3 years at the same party but all my friends said it looked at home in my garage.
    Horkn, clemsonfor and Barcroftb like this.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Its definately loud, but not as obnoxious as i thought it would be.
  9. concretegrazer
    concretegrazer
    Southwest MO
    Zoom zoom.
    Horkn, bobdog2o02 and clemsonfor like this.
  10. bushpilot
    bushpilot
    Eastern Washington
    Well, I hope it is loud enough to distract from the blue color! Maybe that will burn off and you can repaint in a tasteful black ...
  11. clemsonfor
    It is only a 38cc saw!!!
    Horkn, Barcroftb and bobdog2o02 like this.
  12. cus_deluxe
    cus_deluxe
    Northern Michigan
    it has no problem with any rpm, although the response time seems to be a little slower than the .5 seconds advertised.
    Horkn and Barcroftb like this.
  13. cus_deluxe
    cus_deluxe
    Northern Michigan
    i use a combo technique, using my ears and the mfgr's recommended max rpm. i usually tune it right to what is recommended, if i like how it sounds and saws, i leave it. Having a tach is a must for use with limited coil saws.
  14. clemsonfor
    Yea with limited coils u really needs one cause you can't tell is it four stroking cause of the tune or the rev limiter?
  15. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    How do i know which coil i have?
    Blue max
    CS-400
    CS-670
    Horkn likes this.
  16. clemsonfor
    You dont have a limited coil
    Horkn likes this.
  17. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Thats what i thought, but i dont know enough to know yet....
    Horkn likes this.
  18. clemsonfor
    Its a cheap old school saw design .
  19. clemsonfor
    To make it pass EPA they do the band aid fix of slapping a cat in the muffler to burn up excess fuel instead of a redesign of the saw.
    Thats why pulling the cat and a muffler modd helps these saws so much. They were never designed to have a cat in the muffler restricting it so much.
  20. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    And the echos? Any idea on them?
    Horkn likes this.
