How do I tune this saw?
Discussion in 'Chainsaws and Power Equipment' started by bobdog2o02, Jan 26, 2016.
  1. Mrs.Muffinhead
    Mrs.Muffinhead
    Lancaster, PA
    And he is the better cook. :stirpot::grizz:
    This is me with most food:flipeggs:
  2. Canadian border VT
    I want to know what you hit his left thumb with... :D
    my wife took my cordless drill and put a beater in it to do something with breads apparently her and her mom were in kitchen:hair: needed more torque
    I walked away..:bug:
  3. Mrs.Muffinhead
    Mrs.Muffinhead
    Lancaster, PA
    I don't beat him up. He is too good at it himself.
  4. Eric VW
    All I can add is....... Come on Central PA GTG:thumbs:
  5. Barcroftb
    Barcroftb
    The Mitten
    For your blue saw they call it a Pac-Man style tool. IIRC for the Echos you use the spline one. On my cs500p I could use either the spline tool or a screwdriver. The tools in the kit I posted should tackle most of what you would run into for 2 cycle carb adjustment.
    Horkn and Eric VW like this.
  6. Barcroftb
    Barcroftb
    The Mitten
    If it was me I'd leave that whole stupid cat plate out and cut the deflector off the exit port befor I put it back together. I'm sure clemsonfor will be along to tell ya how he did his.
    clemsonfor, Horkn, Eric VW and 2 others like this.
  7. millermodsaws
    millermodsaws
    Once you get that baby all muffler modded don't sweat it. You'll be able to hear the four stroking easy. Holar if you need some help!
  8. mdavlee
    mdavlee
    I'd cut the cat out and leave the plate in but make it hollow if you don't mind noise.
  9. old 040
    old 040
    Buckeye State
    Sure seams like the front half of the cases would get hotter than crap with that cat located where it is.......
    clemsonfor, Barcroftb and bobdog2o02 like this.
  10. millermodsaws
    millermodsaws
    Op I would listen to Nike lee on this. If you remove the plate on this it's gonna be a straight shot from inlet to outlet. It will be ear piercing loud. If you cut the cat off and just make sure where the cat is at there's a nice big hole. Then the sound has to bounce around in the muffler before it comes out. That will tone it down but still allow you good flow.
  11. millermodsaws
    millermodsaws
    A good example of this is the 550xp and 562xp. When I mod these I actually bend a peice if steel. 3 side face the open towards the from of the muffler and weld it down in under the deflector and then make a new deflector. I know confusing. Let me see if I can find a pic. But essentially this makes the sound bounce off the front off the muffler before exiting. Takes a lot of the high pitch crack out of them.
    Horkn, clemsonfor, Barcroftb and 3 others like this.
  12. millermodsaws
    millermodsaws
    Here's pocs of the first 562xp I did. But maybe it'll help explain. When gutted these are a straight shot and loud. By adding the pipe angled forward it helped a lot with the high pitch cracks. A 550xp is actually worse! Lol downloadfile.jpeg downloadfile-1.jpeg downloadfile-2.jpeg
  13. millermodsaws
    millermodsaws
    What they look like finished! :) downloadfile-4.jpeg downloadfile-6.jpeg
  14. millermodsaws
    millermodsaws
    Sorry for the long ramblings but any MM saw gets loud. And I'm one that if I can make it quite and still have the same performance I'm all about it. Cause they still ain't quite. Lol. Now like a 395xp. Not sure that's possible. Lmao. Them mofos are loud! :dex:
  15. mdavlee
    mdavlee
    What paint you using Carl? I've got to buy some and start painting some of these mufflers. I don't have a good way to clean them so I usually don't attempt painting one.
    Horkn and clemsonfor like this.
  16. millermodsaws
    millermodsaws
    It's just header paint. I heat the Mufflers up before painting. Randy/Jeremy trick. But one of these days they sell the high heat powder coat system with oven for iirc $350. I want one of them. Lol.
    mdavlee likes this.
  17. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Has anyone tried packing a cored muffler with stainless steel wool?
  18. millermodsaws
    millermodsaws
    I havnt but it would be worse than a screen at plugging up. I think. Lol. And a pain if it does.
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
  20. cus_deluxe
    cus_deluxe
    Northern Michigan
    id say a little of that reflective tape on the flywheel should allow that tach to work, assuming the tape isnt thicker than the flywheel airgap. i have the fasttach and it works great.
