Husqvarna 350 Rebuild
Discussion in 'Chainsaws and Power Equipment' started by HoneyFuzz, Jan 19, 2016.
  1. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Boy oh boy....that's a nice looking saw !!
    Sounds like it runs just as good !!
    Good job ! Hope mine turns out as well :)
    cus_deluxe, RCBS and BIG DOG like this.
  2. RCBS
    Thanks! There is some paint missing on the clutch cover, but overall for an 11 year old saw she cleaned up nicely. Shoulda heard me cussing first time I put it to wood after all that cleaning! :mad:o_O
    I am dealing with an occasional stall just after coming out of a cut. I'm still a tuning novice, but I'm sure I'll get it properly sorted out with more run time. Haven't had much cutting weather lately...too much mud! Might try to get out tomorrow.
    Good luck with the rebuild, I will be following along!
    HoneyFuzz likes this.
  3. BIG DOG
    BIG DOG
    Windham Ohio
    Well done from one newbi to another!!............:D
    Scotty Overkill, RCBS and HoneyFuzz like this.
  4. RJames
    RJames
    Hey fuzz, really jogged my memory reading this. I did the same thing last winter with my old 350. Haven't ran it much since rebuild but plan to this spring.
    Here it is after disassembly/cleaning:
    cnice_37 and HoneyFuzz like this.
  5. RJames
    RJames
    I cleaned up all the carbon inside, piston looked pristine so I reused it.
    Deleted base gasket, squish is .020, compression after was 155ish. Also did the metal intake clamp. I was lucky that my clamp never cracked, and muffler never once loosened up!! I did use some red loctite on the bolts just for s/g.
    Little advise: hog out the muffler opening or add a second port-made a big difference on mine!
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    That's awesome ! I'll definetly take your advice ! All suggestions welcome :)
    I am a little jealous on how good of shape yours is tho !
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Just waiting on parts :( Hopefully next week will bring them to my door :)
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Well.....I'd hate to speak out of turn...since I'm not done.....but....so far..no reassembly....and there are ALOT of parts !!! But so far with the tare down....and cleaning.. And organizing....painting muffler...etc....I have probably 2 to 3 hours in it total I'd guess . Meteor piston kit $40.....tube of 3 Bond 1194 liquid gasket $8.......crank bearings and seals....$20. ( my bearings are probably fine..but I'm in there now..why take a chance). So that's around $68 !
    I still need fuel line and filter...clutch sprocket...flywheel...and some odds and ends that you may not need. I'd guess I'll have $125 to $150 in it because of other stuff needing replaced. Is the saw worth it ? Nope.....but to me..YES !
    I'd guess an hour for careful assembly too ....and double checking Iol.
    Maybe 2 hours with a beer break lol ;)
  9. Boog
    Boog
    Where my spirit is free
    They are so much fun to work on when they are at this dirty filthy stage huh! ;)
  10. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    So got a few parts in ......
    Started with new crank bearings and seals. The original bearings seem good....but...the new set wasn't expensive....so while its all apart....why not replace em. Cleaned up the crank a little...lubed the pee out of everything....put the new seals over the bearings....which is a tight fit lol ! So far..so good ! IMG_20160126_084315793.jpg IMG_20160126_085129635.jpg IMG_20160126_085408647.jpg IMG_20160126_085414672.jpg
    Stinny, Todd 2, BIG DOG and 1 other person like this.
  11. RCBS
    I debated whether or not to replace the crank seals on my 350 when I rebuilt it. Decided against. Not cost related, but read that they can be a pita. I noticed that I have an oil leak coming from behind the metal case cover on the drive side...gotta get that taken care of.
  12. BIG DOG
    BIG DOG
    Windham Ohio
    Looks good, but don't forget the sealant.......:)
    pantelis and HoneyFuzz like this.
  13. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Definetly...it's warming up inside as we speak ;)
    pantelis and BIG DOG like this.
  14. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    So I was able to get a little more done today....first...as I have read and seen in vids....lightly sand the bottom of the riser on a flat surface...to smooth out any high spots ... IMG_20160126_130755599.jpg IMG_20160126_130927729.jpg
    Bright and Shiney !
    Then time to get the Three Bond out...and put the riser on...didn't know how much it would take.....so I coated both surfaces just to be sure. I'll have to apologize to my daughter...she has one less paintbrush now lol ! IMG_20160126_131335862.jpg
    Went together nice... I also used locktite on the threads of the bolts underneath....but...I hear because of the thread design....the locktite is useless......but I feel better gooping it on and trying :) IMG_20160126_132658422.jpg IMG_20160126_131757538.jpg
    Stinny and pantelis like this.
  15. old 040
    old 040
    Buckeye State
    Did you put any sealant on the outer rubber coating of the bearing/seal?, to be honest, I'm not sure there should be or not, I've never had to tare down one of this series of saw that far.
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    So next step.....Three Bond on the cylinder...to heck with the base gasket lol.....lubed up everything really well....on goes the cylinder....thanks to my handy dandy beloved piston ring compressor kit ! IMG_20160126_133613236.jpg IMG_20160126_134457746.jpg IMG_20160126_135039044.jpg
    All tightened down....ready for the next step....I would have liked to put the new carb boot and metal clamp on before cylinder install....but ....it hasn't arrived yet...so I'll deal with it later I guess :( IMG_20160126_135338838.jpg IMG_20160126_135348107.jpg
    Stinny likes this.
  17. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I pondered this.....I decided not to....as the fit with the seals into the grooves of the riser and plastic holders took alot of effort on my part... So I figured it was good. I hope I made the right move.
    Also....there were no remnants of sealant in those grooves or on the seals from the factory.
    I hope I gambled right !
  18. old 040
    old 040
    Buckeye State
    Did it look like it had any on the old ones when you took it apart?
  19. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Nope .I edited my above post right as you asked that question lol ! We are on the same page buddy :)
    old 040 likes this.
  20. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Definetly sealant on the flat matting surfaces. The stuff turned a whitish brown color over the years..hard to miss.
    old 040 likes this.
