Marking a chainsaw chain
Discussion in 'Chainsaws and Power Equipment' started by schlot, Dec 26, 2015.
  1. schlot
    schlot
    NW Iowa
    I'm no pro when it comes to sharpening chainsaw chains so maybe this has been covered already.
    I tried using a marker to mark the beginning point of where I started but it was hard to keep it marked and often would lose it, thanks to the oily surface or poor lighting, so I did this instead.
    After sharpening the first tooth I grabbed a twist tie and wrapped it around it.
    I'm sure there's other ways but it was simple, and schlot likes simple! :)
  2. concretegrazer
    concretegrazer
    Southwest MO
    That's a gooder idea.:thumbs: I usually can tell when the sharpened cutter comes back around. But on those longer chains it would be nice to see how much is left at a glance sometimes.
  3. saskwoodburner
    saskwoodburner
    Usually a quick wipe with a rag and marker will stick, but your way works without a marker, or a rag!
  4. Warped5
    Warped5
    Northwest IN
    I use a large industrial yellow crayon ... from the local hardware store.
    Mag Craft, HoneyFuzz, HDRock and 3 others like this.
  5. Eric VW
    I like it a laht, schlot :thumbs:
    Some say it's the simple things in life.....
    K.I.S.S.
    Keep...It.. schlot...Simple:thumbs:
  6. Horkn
    I like the marker idea. A red sharpie would probably stand out. Either that or a little white out.
    HoneyFuzz, mdavlee, Chvymn99 and 2 others like this.
  7. bassJAM
    bassJAM
    Cincinnati, OH
    I use a white or green paint marker, but I like the bread tie idea too!
  8. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Silver sharpie
    Woodsnwoods, HoneyFuzz and Eric VW like this.
  9. prell 73
    prell 73
    ia
  10. MightyWhitey
    MightyWhitey
    I mark the bar.:whistle:
  11. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    All my chains have 2 teeth in a row on the same side in one spot. Thats where I start and end.
    Gary
  12. schlot
    schlot
    NW Iowa
    My Stihl is the same way. Easy that way. :)
    clemsonfor, HoneyFuzz and Eric VW like this.
  13. RParrotte
    RParrotte
    Saranac, NY
    I use a yellow paint marker. Sticks out like a sore thumb.
  14. old guy
    old guy
    minneapolis mn
    I found that black sharpy has a way of disapearing, I have a red one that's more of a paint marker that works very well.
    Never thought of the wire tie thing, that looks good.
    John
  15. MasterMech
    I just mark the cutters with blood. That way I know which ones are sharp. :p:doh:
  16. old guy
    old guy
    minneapolis mn
    Yeah, I can't work on chain without springing leaks either.
  17. Chvymn99
    As others have said paint marker ... My neighbor uses metal dye marker or finger nail polish...
  18. Dascro
    Dascro
    Southwest PA
    I wipe the tooth off with a rag, then use a red sharpie. So far, so good.
  19. thistle
    thistle
    Polk/Guthrie Counties,IA
    Black sharpie on the top of the first tooth when I start
    clemsonfor, Eric VW and unclefess like this.
  20. HDRock
    White grease pencil, mark the whole link
    HoneyFuzz, Eric VW and old guy like this.
