I'm scared. Hold me.
Discussion in 'Chainsaws and Power Equipment' started by Jon1270, Oct 9, 2013.
  1. Ironworker
    Ironworker
    Nice saw, awesome score.
  2. the GOAT
    the GOAT Banned
    Alright, didn't want to do it; here is my final offer
    Even trade?
  3. StihlHead
    StihlHead
    The wild west
    OK, how about this mint gem new Wild Thing! This PLUS the $200. Comes with a case and oil... its never been fired up. A virgin saw!
    DexterDay and Grizzly Adam like this.
  4. Jon1270
    Jon1270
    Pittsburgh, PA
    Well, that was fun. I can see why an 8-pin rim would be worthwhile with the shorter bar; it certainly doesn't bog down with the 7-pin.
  5. StihlHead
    StihlHead
    The wild west
    Yep, torque to spare and then some.
    Nice vid.
  6. amateur cutter
    I run an 064 with an 8 pin, & 24 or 28". They will pull it, esp. with skip chain. Nice job on the saw, & yes you suck. A C
    Pallet Pete likes this.
  7. Jon1270
    Jon1270
    Pittsburgh, PA
    Hey, there's a segue opportunity. How do you (and others) decide whether to use skip, semi-skip or full comp? So far all the chains I've tried have been full comp. I understand (or think I understand) that skip-tooth patterns leave more room for chips in long cuts. I imagine that each tooth might bite deeper, and probably behave poorly when cutting smaller-diameter wood. I'm not sure what I'm asking. Maybe specific examples would help illuminate this -- e.g. if you've switched tooth patterns in the middle of a particular log and noticed a big difference.
  8. thistle
    thistle
    Polk/Guthrie Counties,IA
    I prefer full skip on bars over 24". Very little difference in cutting speed (In my experience anyway,YMMV),gives you a little more engine power + clears out chips/shavings better in long cuts.Plus it takes less time to file since there's 1/3rd less teeth...
    Can be a bit grabby in short cuts under 12" sometimes though.My rakers are set a bit deeper than usual,especially for milling & regular cutting big rounds of softer woods like White Pine,Eastern Red Cedar & the occasional Silver Maple.That really flies through the big stuff.Some months ago I milled some Pine & forgot to put a less aggressive chain before starting to cut some super dense Honey Locust a few weeks later....:eek: Was a bit grabby & vibrated a little at first,but that 2100CD just took hold & chewed through it no problem.Nice thing about a 100cc saw,you will rarely find anything to bog it down,even if saw is 30 years old...:smoke:
    DexterDay likes this.
  9. MasterMech
    I did some video comparisons, in 20"-24" Oak, there was little difference. Full-comp was about 3 seconds per cut faster IIRC. Even 28" buried, the full-comp was faster. (Barely.) Softer woods and extra-long cuts is where full skip shines. I do however like it for noodling. :D
    Jon1270 likes this.
