What are y'all working on today?
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Mar 7, 2015.
  1. mdavlee
    mdavlee
    Yes it is. Wish I had a bar to test it on.
  2. The Wood Wolverine
    Wish I was havin' that much fun! Oh well, @ least it's friday ;)
    cnice_37 and mdavlee like this.
  3. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Rob, is that near Shadwell/Milton?
    foragefarmer likes this.
  4. Oldman47
    Oldman47
    Illinois
    It's only Thursday here. Sorry to rain on your parade.
    cnice_37 and 94BULLITT like this.
  5. Guido Salvage
    Guido Salvage
    Trying to refrain from killing a dog...
    Cut4fun, unclefess, Chvymn99 and 4 others like this.
  6. Oldman47
    Oldman47
    Illinois
    I can't use the "like" button on that Guido but appreciate your restraint.
  7. Boog
    Boog
    Where my spirit is free
    Mounting some new "TireRack" snow tires on my daughter's Honda CRV, looks like just in time!
  8. foragefarmer
    foragefarmer
    Central, Virginia
    Yep, it is Shadwell. Next to Luck Stone.
    How are you holding up? Did you sell that Studebaker truck?
  9. Guido Salvage
    Guido Salvage
    Doing well, pacemaker was installed 5 weeks ago today. The truck did not sell, but I am working on a plan to clear out my building next year. Let me know if there is anything you are interested in.
    mdavlee likes this.
  10. The Wood Wolverine
    Gotta tree fiddy on my bench. My nephew needed a saw so I found a decent one on craigs. Metal clamp is due tomorrow and I've already put loctite on the lower case screws. Heck the piston still has all its machine marks!
    Chvymn99, mdavlee and cnice_37 like this.
  11. cnice_37
    cnice_37
    My first saw was a 351, burned up the top end because of the intake clamp. Learned a lot after that mistake!
  12. The Wood Wolverine
    Yep, I haven't suffered the consequences from one yet...
  13. Machria
    Machria
    Long Island, NY
    Installing a new Carb, and starter re-coil unit on my 3000kw Kipor generator last night... These things are nuts! The thing is so stuffed into the case that when you unbolt the case it pops open like it's spring loaded! Fun fun fun getting it all back into the case!
    Deacon, Chvymn99, mdavlee and 2 others like this.
  14. clemsonfor
    That looks like a freaking nightmare!!! Makes me glad that I have the old traditional metal frame style generator!!!
    mdavlee and Canadian border VT like this.
  15. cnice_37
    cnice_37
    It's like the mini-mac of generators, right colors and all.
  16. Machria
    Machria
    Long Island, NY
    You know, the first time I opened this thing up a few years ago to change the fuel pump (which ended up not the problem!), it was a "nightmare". Took 10 minutes to open up, 10 minutes to swap out the fuel pump, and then 4 hours plus to get the dang thing back together properly. It's like a jig saw puzzle. BUT, now that I know how to do it and the correct order to do it, and what to hold when putting bolts back in.... It actually isn't 1/2 as bad as is looks, and only takes 1/2 hour or so.
    But I'll tell you this, this 3kw unit is GREAT. Starts right up, and when it's running full blast you can barely hear it. In addition, it's a "Signemaster" which means it has an inverter on it so it is always outputting a nice clean signal. Those "frame" units you refer to not only do not output clean signals and can ruin modern electronic equipment, they are LOUD! I had one of the cheap ones and it was terrible. My brother has a 3kw diesel frame type unit, it runs like a champ, but you can hear it 4 miles down the road, and it takes 3 people to lift it and put it in a truck. My Kipor weighs 40lbs, you just pick it up by the handle. ;)
    Chvymn99 and clemsonfor like this.
  17. The Wood Wolverine
    350's gone, but he also dropped this off:
    concretegrazer and mdavlee like this.
  18. clemsonfor
    I k how they can ruin modern electronics. But honestly I do t have much I run o. It other than fans lights tv and satellite and refer and freezers.
    And I dont really have a tv newer than a decade. The flat panel in our room is given to is and is like 3"s thick!! Its probably close to 8 yrs all other tv are tube types.
  19. mdavlee
    mdavlee
  20. LinkedXJ
    LinkedXJ
    Working on cleaning glass out of my trucks back seat, its bed and out of the gravel drive way under the truck.
