Sierra Stove
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Glen-NKY, Nov 7, 2015.
  1. Glen-NKY
    Glen-NKY
    Northern Kentucky
    Have had this stove laying around for 15ish years, probably was bought used at that time. Was wondering if anyone knew much about them? I was thinking as others suggested a welded in baffle would be well placed, then also a pipe baffle. Any thoughts, experience, etc would be appreciated.
    HDRock and fox9988 like this.
  2. WeldrDave
    I've heard of them and only seen one in an antique shop, "working" . Pretty neat! Putting a baffle in wouldn't take much at all. I wouldn't baffle the pipe, to much restriction. There were "MANY" off shoots of the Fisher when they hit the market, that stove I believe is one of those. With a little research I'm sure you can find lots about it. :)...
    Glen-NKY likes this.
  3. Glen-NKY
    Glen-NKY
    Northern Kentucky
    Thanks Weldrdave. It certainly resembles the Fisher, I put a baffle on the pipe and it was too much, needed to run fairly wide open. I did a Google search the other night but not much success. I'll continue on. Although the first night I did have hot coals 7.5 hrs later...
  4. rookie1
    rookie1
    Here is a couple pics of my Sierra. I bought it used and can't remember model name. Mine has a baffle of sorts in it and I have a damper in the pipe. image.jpeg image.jpeg image.jpeg
    Bags and HDRock like this.
  5. fox9988
    fox9988
    NW Arkansas 72717
  6. fox9988
    fox9988
    NW Arkansas 72717
    ^^ This one was in my family for decades. I burned it for ~12 years. Good solid stove.
    HDRock and rookie1 like this.
  7. Glen-NKY
    Glen-NKY
    Northern Kentucky
    Nice pics fellows. my little Sierra really does crank out some heat. Thanks. If you get a chance when the stove is down would you mind to take a picture of the baffle of sorts? Thanks.
    rookie1 likes this.
  8. rookie1
    rookie1
    Baffle is channel piece welded to angle and top piece that direct exhaust up and around then behind part where door is into pipe. image.jpeg
    HDRock and milleo like this.
  9. brenndatomu
    My inlaws have that stove...it does make some heat, too bad a full 50% goes up the chimney.
    Did you make and add that? Looks a whole lot better than the "baffle" in the inlaws Sierra...
    Edit: Never mind, I just noticed the upper handle, I think you have the Classic Turbo Burn 2000T.
    I believe my IL have the older, more basic "campfire in a metal box" Hearthstone Classic
  10. rookie1
    rookie1
    Its all stock. I bought it used from CL about 10 years ago and cant remember model name. Ill have to check metal tag on back.
  11. fox9988
    fox9988
    NW Arkansas 72717
    I sold mine when I bought the Keystone.
  12. rookie1
    rookie1
    Tag says T1000 built in 8/79.
  13. Bags
    Bags
    Union, KY
    I've been looking for a similar stove and missed out on a pretty nice Fischer this AM. Ticked me off! It was a Mama bear I am fairly sure. It was only posted on CL for about 8 hours before I inquired. It went fast.
    Anyone know a a good deal on one? Any Fischer at all I'd entertain or Sierras or the likes. Thanks I live close to the OP but my trucks have wheels and I'd travel some depending.
    WeldrDave likes this.
  14. Astrolite
    Astrolite
    I know this is an old thread but here are a couple of pictures of my Sierra stove. Parents bought it for me about 35 years ago. Heating my house as I type. Installed a simple plate steel baffle last season and it's working great!
  15. Coaly
    Coaly
    NE PA
    Built by "Self-Sufficiency Products" ; (Jim Cook) One Apppletree Square Minneapolis, Minnesota. Sierra is the stove name, not company name, and is not related to Sierra Products Inc. NV that makes the current Sierra Stove since original trademark expired.
    Designed for farm use. Builder suggested loading at night and turning down air dampers for around the clock burn. Like a Fisher, they burn down to fine ash in the front near air intakes leaving coals and charcoal at the rear. This is due to the updraft principal used with the low mounted air intakes, another feature the Fisher patent didn't withstand in a patent infringement case. Removing ash from the front each day before raking coal pile ahead to load on prevents the need for allowing it to go out for ash removal. This is the best burning practice for any stove operated 24/7 and this updraft design aids in preventing air from reaching the rear. The deep single door door stoves are best suited for this type burning. Like any fire bricked stove, allow 1 inch ash on bottom at all times.
    The first two models made in 1977 were the Sierra 150 and Sierra 300.
    150 is 16" wide X 24" deep and takes logs to 22"
    300 is 18" wide X 32" deep and takes logs to 30"
    With measurements of your stove I can give you more details.
  16. lefties
    lefties
    I just bought my second one 2 days ago...its same model pictured above with side door. new door gasket and firebricks...
    fox9988 likes this.
  17. lefties
    lefties
    sierra must have started listening to consumers. Now they make a look alike stove. Price is over$ 2000.00....i bought a stove in tsc about 8 yrs ago....airwash,,catalytic and total junk,wouldnt heat my livingroom let alone my house. I returned it.
    shack likes this.
  18. shack
    shack
    Upstate NY
    Like many things ...same name...not the same quality or performance.
  19. lefties
    lefties
    WIN_20180227_08_10_18_Pro.jpg WIN_20180227_08_10_18_Pro.jpg WIN_20180227_08_10_18_Pro.jpg WIN_20180227_08_09_57_Pro.jpg WIN_20180227_08_10_18_Pro.jpg WIN_20180227_08_09_57_Pro.jpg WIN_20180227_08_09_58_Pro.jpg FOR SALE
  20. shack
    shack
    Upstate NY
    Nice...looks to be in pretty good shape. Congrats.
