Chain sharpening tutorial.
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, Jun 11, 2014.
  1. super3
    super3
    Yes, closer to 50°. Yours may vary a bit on the scale.
    Try one of these,
    HDRock likes this.
  2. HDRock
    X2 on the Wixey, I have had one for a long time they work great, I use it mostly setting up things in the woodshop
    clemsonfor likes this.
  3. clemsonfor
    Yea your right about that. I know I am not set on 60...I will have to look. I think I took a brand new chain and set it on there and set the wheel to that angle. Now thinking I think it might read about 55? But if I remember there is two indicators on it and I dont think either is the same when the head is locked in. IE one may read closer to 60 and other is like 55? I will look tonight.
  4. clemsonfor
    The one I have is the same one as the timber tuff that is a copy of that oregon 511?? I think it is at least?
  5. Oldman47
    Oldman47
    Illinois
    Looks nice and sharp but check your filing angle on the rakers. The stamped line on them is the angle you are supposed to maintain. Right now you don't wa
    Get it right. That is CDO, alphabetical as it should be.
    Jeffrey Svoboda likes this.
  6. 94BULLITT
    94BULLITT
    Frederick County, VA
    You have a Roughneck grinder from NT don't you?
    Eric VW likes this.
  7. 94BULLITT
    94BULLITT
    55/30/10
    concretegrazer and Moparmyway like this.
  8. clemsonfor
    I just sharpened some at 55/39/10 and it looks good. Can y'all show pictures of your table tilt just so I can be sure I am going the right way. Chain on the grinder pics please :)
  9. 94BULLITT
    94BULLITT
    When I sharpened the left side cutters, the one farthest from you when it is in the vice, I had the vise tilted inward. I had it tilted outward for the right side.
    Moparmyway likes this.
  10. clemsonfor
    I think were tilting the same way then
  11. Moparmyway
    Moparmyway
    New York
    Hows that chain cut for you ?
    94BULLITT likes this.
  12. 94BULLITT
    94BULLITT
    I tried it this morning. It cuts good. It self feeds like a filed chain. Thanks for your help.
  13. Moparmyway
    Moparmyway
    New York
    My pleasure Sir !!!
    Happy that its cutting better for you !
    94BULLITT and clemsonfor like this.
  14. clemsonfor
    Mopar can you post a pic of the vise and the table tilt with a chain so I can make sure I am doing out right.
    The one I ground just cut like crap. I thought I did 55/30/10. But the chain I did was jacked up to begin with looked like they were cutting dirt. Tops of cutters looked like they were sharpened!!! So I had to grind like 1/8" off tooth. I didnt go as slow as I should had the rolled over metal and blued cutters but I was just trying to see what it would do and was using that as a test chain. I guess it wasnt the best since I too so much off. I usually take no where near that off!!
  15. Moparmyway
    Moparmyway
    New York
    Can post up pictures later tonight or tomorrow, but if you have a 511 series, or knockoff, the tilt for a left cutter will be correct when you loosen the tilt knob and pull the knob to you, tilting the table towards the back of the frame
    Right hand cutter will be correct when you push the knob away from you, tilting the table towards you
    Post up a few pictures of your cutters .............. easier to look at the tooth and see whats happening Clem !
  16. Hedgerow
    Hedgerow
    SW Missouri
    Most likely did not get all the damage removed.. On real buggered chains, sometimes it takes a few more touch ups to get it really proper.
    Those round ground, full chisel cutter points are easy to litterally "bend downward" when they hit something hainus. like rock or t-post or...
    And they can be damaged a long way back.
    MasterMech, mdavlee and Moparmyway like this.
  17. clemsonfor
    I dont have the jacked up chain. It was a guy I know I did it for him kind of testing my new grinding angles and to salvage a trashed chain. He hand files and there is no way he would have wanted to file that much damage out by hand. He is getting a larger bar and chain anyway.
    Will maybe try to get a few teeth ground late tonight after my boy goes down.
  18. clemsonfor
    Thats a very good possibility. I think a few teeth for sure did not have that point to them on the top.
    This chain literally was cutting dirt. Would burn the wood and smoke if u cut and the top plates had lots of damage from I guess dirt? I am not so sure that this was not a tree service saw that they cut roots with or something?
  19. 94BULLITT
    94BULLITT
    Clem, a magnifying glass or magnifier app may be helpful to look at the cutter.
  20. clemsonfor
    Ok I hit two teeth. Did not change anything from before. This is 55/30/10. I only did two cutters on the I guess left side it is? Pic of the table tilt to be 100% I am tilting right way. uploadfromtaptalk1446174169841.jpg
    And then some pics of the tooth. Havent measures or filed the raker in I am not sure how long so forget raker height I'm this critique.
    To me it looks as good and a bit better than before I changed and I could live with it then. I think that jacked up chain I just didnt get all the damage out and a combination of the edge metal that was left from me grinding the heck out of the chain as I was blueing the cutters :). Before I was grinding like about 58/30/0 uploadfromtaptalk1446174465988.jpg
    [​IMG][/IMG]
