Napoleon NPS45 exhaust blower motor and impeller
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Geek, Oct 16, 2015.
  1. DexterDay
    We ended up plugging that entire 3rd row that wasn't plugged yet. Pics only show 3 rows plugged.
    That stove burned like a champ after that.
    Granted Magnum came out with an upgraded combustion blower and impeller to overcome the burn issues. My buddy just modded his pot to accommodate airflow.
    The more air you get "under" the pellets? The better! :)
    slvrblkk and imacman like this.
  2. Geek
    Geek
    :hair:
    Ok, sounds good.
    BTW - trimmed feed rate and air last night after turning stove, checked this morning and seems like the change didn't make much difference.... :hair:
    WTF...:picard:
    Burning a bag of Lignetics.
    imacman and slvrblkk like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    That sucks!!!
    imacman likes this.
  4. Geek
    Geek
    I burned in the lowest heat but that shouldn't matter.
    imacman likes this.
  5. imacman
    imacman
    Denver, NC
    As you probably already know, "Low" on most pellet stoves is the toughest to get a decent burn at.
    jtakeman likes this.
  6. Geek
    Geek
    I know, but turning up the heat would mean more pellets going to burn pot, hence more bunch up...I'm in a lose-lose situation it seems..:picard::picard::picard:
    slvrblkk likes this.
  7. imacman
    imacman
    Denver, NC
    Most typically, pellet build-up is one of 3 things: a dirty stove and/or exhaust system, a failing exhaust fan, or air leaks (bad door/glass gaskets).
    savemoney, Geek and slvrblkk like this.
  8. Geek
    Geek
    Just wanted to show you how the burn pot looks like after running stove for 12 hours, unburned pellets bunching to the top and flame lazy as hell...can you feel my frustration?? :mad::hair::hair:
  9. slvrblkk
    slvrblkk
    Northampton, PA
    Geek...when is the last time you had your comb. blower out?
    Geek likes this.
  10. Geek
    Geek
    Last year.
  11. slvrblkk
    slvrblkk
    Northampton, PA
    How much have you run through the stove since then?
  12. Geek
    Geek
    Probably over 2 tons but remember that I have cleaned since, using vacuum from outside, at least 3 times.
    I just cleaned again system from outside a couple weeks ago before season started.
    The times I removed the motor it is actually relatively clean inside there, again because the cleaning with the vacuum from outside.
    This stove worked fine at least the first season.
    I am seriously thinking on ordering the Harman motor tomorrow as the last resource..!!!
  13. slvrblkk
    slvrblkk
    Northampton, PA
    As long as the stove is definitely clean and all your gaskets are good with no leaks then this would point to the comb blower.
    I still feel the leaf blower or air compressor might do wonders, if not, then grab the new blower which you might need anyway if it's making noise.
    Geek likes this.
  14. Geek
    Geek
    Cleaned the burn pot, here's how vibrant is the flame with air flow, nice flame. I'm burning good pellets so no clinkers when I cleaned it but seemed like pellets not burned completely, hence the bunch up..
  15. slvrblkk
    slvrblkk
    Northampton, PA
    Geek...when your stove is on high does it look like this?
    Geek likes this.
  16. jtakeman
    In that video steve posted at 1.57 mark, They said something odd! Its rated to burn premium grade softwood pellets only, Yet they show Cubex hardwoods???
    Doubt it means anything, But it made me chuckle.
  17. Geek
    Geek
    Up the heat to 4 and flame has like an orange tail and to me is dispersed or lazy? Not uniform all the way up like in the video.
  18. slvrblkk
    slvrblkk
    Northampton, PA
    Geek....does your firepot "teeter" at all when it's in the stove or does it sit flush?
    When was the last time you had exhaust port open and cleaned behind the firebrick?
  19. savemoney
    When I had those issues, I exhausted about everything until I came to the fact that it was the ash pan door not closed and sealed properly. Check the gasket to the ash pan door and see it that is reasonably tight.
  20. Geek
    Geek
    Picture attached, note that the upper side of glass is dirty but you can see the flame.
    I cleaned glass Friday night.
