Hey old fellas....
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Geek, Oct 10, 2015.
  1. slvrblkk
    slvrblkk
    Northampton, PA
    Geek...I don't know what your venting or setup is like but you might want to consider a leaf blower/vacuum for your stove. You might have ash plugged up somewhere that your current vac can't suck out. I believe can be had for $40-60 or check out Craigslist.
    Don2222 can hook you up with a new comb. blower and updated impeller. You should be able to buy the new impeller and slap it on your current blower. I think they are relatively cheap.
    ivanhoe, eatonpcat and wildwest like this.
  2. Geek
    Geek
    I will send a PM to don2222
    I'd love to try the impeller and see what happens, albeit it can be used with current blower.
    The vacuum I use from outside is very powerful. I don't know where else soot can be plugged up. I have a leaf blower but never tried it on the cleaning since it'd be pointing down/up and not away from the house?
    ivanhoe, slvrblkk and wildwest like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    Don't forget to mention you're a member so you get your 10% off. :D
    ivanhoe, wildwest and eatonpcat like this.
  4. imacman
    imacman
    Denver, NC
    In most cases, a high MPH LB will out "suck" the shop vac. I'd give it a try, and I'm sure there must be some sort of plastic elbow at a big box or hardware store that can be "McGiver'ed" onto the end (duct tape?) to shoot the ash away from the house.
    Don't forget....IF the interior walls of the stove are steel, you can do some banging on them to help dislodge hidden, caked-on ash. I was VERY surprised how much came out the 1st time I tried it. BUT, if the walls are cast, don't try it. Remove any "firebrick" first too.
    bogieb, ivanhoe, will711 and 3 others like this.
  5. wildwest
    We did LBT for the first time this weekend, it involved duct tape....
  6. DexterDay
    I'd cover every other hole in the sides of the pot. All of those holes are not needed for combustion.
    As for the impeller? I bought a large impeller from Don2222 last year for my furnace. With the new motor, impeller, manifold (exclusive to that furnace), and the burn pot mods, I doubled the amount of air through my pot. It's a very clean, hot, and efficient burn
    My OEM impeller is on the left. The middle impeller in the middle is an OEM unit from my Quad CB 1200, and the one on the right is the new/large impeller from Don.
  7. Geek
    Geek
    don2222 returned my call and recommended first to haul the stove out and with an air compressor to blow every hole and within the exhaust blower area, in both directions.
    If that doesn't fix the air flow then buy the exhaust blower and impeller assembly ($200 plus shipping)
    I don't have an air compressor so hope my leaf blower can do the job?
    This is a project for Friday..,
    wildwest, ivanhoe, imacman and 3 others like this.
  8. krooser
    krooser
    Waupaca, WI
    Rent a small air compressor if you must…
    wildwest, imacman and ivanhoe like this.
  9. Geek
    Geek
    I may need to, $25 for 4 hours.
    I am also thinking if using my leaf blower may do the job, we'll see.
    ivanhoe, imacman and wildwest like this.
  10. gbreda
    gbreda
    NH
    Welcome aboard Geek, its been a while. :yes:
  11. Geek
    Geek
    Thanks...
  12. Spock
    Spock
    MA
    Hey geek, nice to text ya.
    ivanhoe, imacman, Geek and 2 others like this.
  13. wildwest
    I have seen compact pancake compressors that cost just a bit more to purchase.
  14. mithesaint
    mithesaint
    NW Ohio
    Yep. I have a $39 compressor from Harbor Freight that I've had for at least 6 years now. It doesn't get heavy usage, but it ran a framing nailer and a trim nailer when I finished 800 sq ft of my basement. Still going strong. I bought a lot of harbor freight tools to get started, intending to replace them with nicer stuff once they broke...the reciprocating saw and small compressor are still kicking!
    ivanhoe, imacman, wildwest and 2 others like this.
  15. imacman
    imacman
    Denver, NC
    Craigslist in my area always has an assortment of compressors pretty cheap.
    wildwest, ivanhoe and Geek like this.
  16. bogieb
    The Chows and ThermoGlo's seem to be on par with ash and heatm although the Chows seem to have just a bit less (no scientific observation though). So to me, the main difference is length and uniformity of length.
  17. Old Fart from Eganville
    Eganville, Ontario
    Welcome aboard Geek. I am new here as well and cant say enough good about the site.
    Old Fart
    wildwest, gbreda, bogieb and 4 others like this.
  18. Scot Linkletter
    Scot Linkletter
    Athens, ME
    I have that exact same stove in the office.
    When I've had trouble with air flow in this stove it's been 3 different problems:
    1. The door or the ashpan door weren't sealed well.
    2. The firepot wasn't seated correctly, or was in backwards, or had ash underneath it, or it's holes were plugged.
    3. On both the left and right side of the back wall, toward the bottom, are 2 removable covers. Mine was full of ash inside and had to be vacuumed out.
    There's a 4th I just thought of, someone bumped into the damper rod on the side and pushed it in once. I typically pull it almost all the way out.
    wildwest and slvrblkk like this.
  19. Geek
    Geek
    Thanks Scot, I found that the issue was a blockage in the OAK, the outside screen seemed clean to the eye BUT there was lint formation blocking the air from coming in.
  20. gbreda
    gbreda
    NH
    Thats great Geek !! Simple fixes are always nice :thumbs:
