Who's firing up the stove tonight ?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Russell, Oct 1, 2015.
  1. wildwest
    Wyoming high plains
    So, I am hoping for LBT this tonight or tomorrow. So far he has only swept the pipe. Do the LBT before detailed cleaning to get most the junk out? Or after to get stuff out of the nooks and crannies?
    Russell and ivanhoe like this.
  2. jtakeman
    I am an after.
    Might be a poll of the crowd?? ;)
    Russell, ivanhoe and wildwest like this.
  3. wildwest
    Wyoming high plains
    Good idea!
    PS, crappy chillly here too, all day.
  4. wildwest
    Wyoming high plains
    Do you sweep too? OR only LBT?
  5. jtakeman
    Yes, I sweep the vent first and clean the stove inners. Then do LB.
  6. IHATEPROPANE
    IHATEPROPANE
    I dump the ash pan (vacuum it up), then hook up the leaf blower. Once the cloud starts to go away, I take a wire brush to the heat exchanger and tap. Once that cloud settles, I in hook the leaf blower and put a chimney cleaning brush in my drill and go in and out of the vent. Hook the leaf blower back up and suck out whatever is left. Works like a charm.
    As you can see I run a dryer vent from the leaf blower to the vent. Get the ash away from my house and closer to y neighbors.
    smoke show, ttdberg, gbreda and 10 others like this.
  7. wildwest
    Wyoming high plains
    Thanks!
    ( and :rofl: :lol: on dryer vent )
    ttdberg, Russell, slvrblkk and 2 others like this.
  8. krooser
    krooser
    Waupaca, WI
    I've got the shop stove going tonite…. may be a good time to give the old St Croix it's new paint job.
    Of course the wife wants to go to the talkies so we'll see how much work actually gets done!
    ttdberg, gbreda, Russell and 4 others like this.
  9. wildwest
    Wyoming high plains
    What are talkies?
    ttdberg, Russell, imacman and 2 others like this.
  10. will711
    will711
    Pocono Mts.
    Movies
    ttdberg, Russell, imacman and 4 others like this.
  11. krooser
    krooser
    Waupaca, WI
    Darn young-uns...
    ttdberg, ivanhoe, gbreda and 5 others like this.
  12. wildwest
    Wyoming high plains
    Darn womens...
  13. gbreda
    gbreda
    NH
    Ive found a sure fire way to not have to fire the stove yet...Since it is still 60ish in the house in the morning, go outside to let the dog out with your bare feet and shorts on. When you come back in it feels soooooo warm :rofl: :lol:
    ttdberg, ivanhoe, Russell and 4 others like this.
  14. gbreda
    gbreda
    NH
    Never done a LBT-I havnet found a reason to as there are no real nooks or crannies in my stove to hide ash. Nothing that a vac and an old paint brush cant find
    ttdberg, ivanhoe, Russell and 3 others like this.
  15. will711
    will711
    Pocono Mts.
    I haven't either and that's what I use too shop vac and paint brush :yes:
  16. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    I was not going to give in yesterday, but with the house in the low 60's and arthritis I had enough and decided it was time to warm the bones. Ran the stove most of the day yesterday. I drifted off about 8 and woke up at 10 and felt like a lizard under a heat lamp. House got up to 77 degrees so I killed the stove for the night!
  17. imacman
    imacman
    Denver, NC
    No stat on the stove??
  18. brokenwing
    brokenwing
    No I do not run a stat on the stove. Problem being Is without doing a modification to the burn pot you occasionally get a smoldering fire in the ash pan after the stove shuts down. It has happened twice and left a haze and terrible smell in the house so I do not risk it! Once we get into the real cold the stove will run non stop until I shut it down for cleaning, so I have never worried with it. I shot the pic last year of a ash pan fire while the stove was running.
    ttdberg, ivanhoe, gbreda and 3 others like this.
  19. ChuckinMichigan
    ChuckinMichigan Banned
    Southeastern Michigan
    Ha! :rofl: :lol:
  20. CleanFire
    CleanFire
    No LBT here, not needed so far. (But piping and flue block plate are easily accessed & removed, so only 15-20 minutes to unhook and put back together.)
    We do use a small (3 gal.) air compressor w/ blow gun tip on deep cleaning to blast out the passages in the stove - that gets a good amount of ash from around the heat exchange tubes I'd otherwise miss w/ the brush though.
    ttdberg, ivanhoe, gbreda and 2 others like this.
