Seepage pit Q (insert poop joke here)
Discussion in 'Everything Else (off topic)' started by cnice_37, Sep 28, 2015.
  1. basod
    basod
    Mount Cheaha AL
    If you know where the tank is you should be able to find all the corners of it by probing with a rod(I used a piece of rebar vice grips and hammer as my clay soil was like concrete this summer)
    The outlet "should be" in the center of the narrow side(usually4x8' tank)
    The probe depth of the tank and any slope in the ground towards the cesspool should tell you if the concrete is an additional seepage field - if that makes any sense?
  2. cnice_37
    cnice_37
    I gotcha, here's some highly professional sketches of my chit-uation :p The mystery structure is a good 30 degree angle to the tank. I know the tank is square to house as the lid was. And yes, we have 2 swingsets.... don't ask; at least they were free and I just had to disassemble, haul and re-assemble.
    basod and wildwest like this.
  3. basod
    basod
    Mount Cheaha AL
    Any pictures of the concrete pieces?
  4. basod
    basod
    Mount Cheaha AL
    It's possible they added leaching chambers or galleys to the pit.
    The leaching field is dictated by number of bedrooms in the house. You figure in MA even back in 85 they had code requirements.
    cnice_37 likes this.
  5. cnice_37
    cnice_37
    I'll post some when I'm brave enough to face the elements.... which means probably next week :D
  6. cnice_37
    cnice_37
    This is the most likely scenario if my archaeology proves it is a true structure.
  7. Canadian border VT
    if it's small could be a D box or distribution box to lines. depending on topography my guys would put bends in to keep it deep enough and pitch. Easier than hauling in more soil...
  8. wildwest
    What a FUN yard! When can you babysit?
    papadave, Woodwidow and cnice_37 like this.
  9. basod
    basod
    Mount Cheaha AL
    Any chance you have a floor drain in the garage? I don't know if they were against code by 1985.
    The other possibility if it's not part of septic could be a diffuser for basement sump pump. I remember my grandfather backfilling our septic tank when I was kid(probably around 1985) after sewer was installed. That house was built in the late 60's and had a drain tile system for the sump pump discharge. I had to disconnect the pump outflow and run it to the street during a turdfloater tropical storm remnant ~96. Lost my battle with the rain running 2 pumps and bucket brigade for several hours, hydraulic cement started popping out of the rebar/form knockoffs
  10. Greenstick
    Greenstick
    Might be a case of the septic tank was ok but the drain field collapsed so they took and dug a new drain field and hooked into pre existing part of drain feild or into septic tank and left old one for a keepsake instead of ripping up more yard and additional expense. This was done at a house I rented. Not sure if it was the right way but that's how they did it.
  11. cnice_37
    cnice_37
    No garage here unfortunately and no sump pump. I was in my good clothes so I haven't dug any further but the rain washed the concrete to give you a better view of one of the sides. That long piece I haven't found the bottom of. IMG_20151001_170702731[1].jpg
  12. basod
    basod
    Mount Cheaha AL
    Sure looks homemade cinder blocks poured together
    If its that far open and doesn't smell like doo-doo it's probably not septic related.
    What about gutters? any downspouts run to drain pipes?
  13. cnice_37
    cnice_37
    Yes, all downspouts run underground to many different areas. This guy was nuts for that, as I learn of new outlets yearly. Could be a dry well for rain water? There are a a mess of drains under the deck that look to be disconnected over the years. You could be on the right track.
  14. basod
    basod
    Mount Cheaha AL
    being a homemade tank that's probably what it is.
    Could be all/some of the downspout drains blocked up over time and instead of paying for a hydro-jet they just abandoned them.
    I'm surprised you don't have a sump pump figured for sure with a basement(looked like a bulkhead door in house picture)
  15. cnice_37
    cnice_37
    Yes, no sump the house is dry except for March of 2010 when we had the "100 year flood."
  16. wildwest
    cistern?
  17. mattjm1017
    mattjm1017
    Judging from the pictures you have posted I would say that you have indeed found Hoffa.
    cnice_37 and wildwest like this.
  18. TurboDiesel
    You need to call Heraldo. He'd find out whats in there...:rofl: :lol: :picard:
  19. Ole yukon
    Ole yukon
    Southern Indiana
    I would guess that it would be a pit for downspouts also.
    basod, cnice_37 and wildwest like this.
  20. cnice_37
    cnice_37
    I reburied Jimmy for another 30 years
    mattjm1017, Loon, unclefess and 4 others like this.
