Cleaning Pellet Stove W/Leaf Blower
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by SKEETER McCLUSKEY, Sep 25, 2015.
  1. Papelletman
    Papelletman
    Plymouth Meeting Pa.
    wildwest and will711 like this.
  2. wildwest
    Is this the vacuum switch? What part(s) need disconnecting?
    IHATEPROPANE and slvrblkk like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    Just take the hose off of it. If it has two nipples on it make sure you put it back on the right one. Or you can take the hose off wherever it goes to if it's easier to get at.
  4. wildwest
    Thank you, bookmarked. I will use a sharpie marker.
    jtakeman, IHATEPROPANE and slvrblkk like this.
  5. will711
    will711
    Pocono Mts.
    :whistle:
    smoke show, bogieb, imacman and 5 others like this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    :rofl: :lol: yes, preferably. :D
  7. wildwest
    That haircutting pic has all you gentlemen in a good mood :rofl: :lol:
    eatonpcat, smoke show, bogieb and 7 others like this.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Gentlemen? :rofl: :lol: I'm in a good mood :D
    eatonpcat, imacman, ttdberg and 4 others like this.
  9. will711
    will711
    Pocono Mts.
    I'm always in the Mood :whistle:
    eatonpcat, imacman, ttdberg and 3 others like this.
  10. wildwest
    what is that?
    bogieb likes this.
  11. wildwest
    Happen to know which one I have? (I've already used the orange mallot)
    slvrblkk likes this.
  12. wildwest
    A member here that does maintenance for a living was thrilled with his Toro. I think they need to exhaust out the back vs the side.
  13. slvrblkk
    slvrblkk
    Northampton, PA
    I believe yours is steel, so you good!
    imacman and wildwest like this.
  14. DexterDay
    Great point for newbs who are looking for one.
    This is a must. It can't just be a leaf blower. Remember, you are "sucking" the ash out of the vent/stove. .
    So it HAS to have the vacuum option. Plus, that long neck helps with making an adapter to fit your stove vent.
    I have a Troy-Bilt unit that is rated for 450 CFM and 240 MPH. Works great.
    I cut the vacuum suction tube down until I could fit a 4"-3" PVC reducer in it, then used liquid nails to make it permanent also seal it all up. .
    The 3" end fits on a 3" pellet vent (add some tape to seal) and it slips inside a 4" (also add tape to seal).
    ttdberg, imacman, slvrblkk and 2 others like this.
  15. jtakeman
    I gotz the same one. Does a good job on leafs too! :whistle:
    :D
  16. imacman
    imacman
    Denver, NC
    Hmmm.......my eye spies some PTL's under the yellow plastic.:thumbs:
    ttdberg, DexterDay and IHATEPROPANE like this.
  17. DexterDay
    Yep. I have 2.5 ton left of the 6 ton I bought last saeson. :thumbs: I need to buy a ton of some primo to make it through this season. But that's the last ton of PTL that needs moved downstairs
    IHATEPROPANE, slvrblkk and ttdberg like this.
  18. Tullytown
    Tullytown
    North of Phila Eagles.
    From Inside the stove behind the removed exhaust blower I push the ash from The exhaust tunnel Towards the Outside with a stiff bristle brush..
    It drops down to the bottom of a 90[still inside as shown]... then I connect the leaf blower while plugging up the vertical outside exhaust with a rag so as to get best suction.
    Remove the same rag then stuff it in the horizonal pipe so as to get the vertical pipe cleaned with again, best suction.
    Oh, and I also leave the door open a bit to save possible? damage to vacuum switch..
  19. bogieb
    My own special version of the LBT (the Very Best Trick maybe? :rofl: :lol:) - used only when I haven't had enough caffeine. My fingers sometimes get serious Alzheimer's and can't remember where the keys are.
  20. wildwest
    :thumbs:
