Red Oak drying study
Discussion in 'The Wood Pile' started by Machria, Jan 12, 2015.
  1. Machria
    Machria
    Long Island, NY
    LOL!! :rofl: :lol: Actually, I needed that for myself to understand. :cheers:
  2. Paul bunion
    Paul bunion
    I have some pieces of oak from July1 that are close to what you have. They are near terminal, they are not going to lose much more at all. A loss by 1/3 of weight means you went from somewhere in the range of 80% to 20% or from 50% to zero. There isn't much left to squeeze out of them. If you use a scale that is sensitive to a gram you will find them gaining and losing 15 grams (or 1/2 oz) each day,picking up moisture at night and dropping it again during the day. I doubt you will get another 5% by weight out of them even if you put them adjacent to your stove come this fall.
    Also remember that the actual humidity on the surface a piece of wood in the direct sun is drastically reduced by the heat of the sun. And that is where the evaporation happens. Even if ambient humidity is up there what is getting direct sun is down near zero at its surface. The fact that ambient RH is 90% is reduced by the direct sunlight. Add a little bit of breeze and the moisture is gone. Drying conditions in the hot sun can't be beat. If it had been storming 2x a week all summer long you would have much different results.
    red oak and Backwoods Savage like this.
  3. Machria
    Machria
    Long Island, NY
    What's amazing to me is, how everyone says you really need 3 years on Red oak? They must be in very wet area's or something....
  4. Hog_Hunter_57
    Hog_Hunter_57
    Mt.Pleasant TX
    I cut it one year and burn it the next year.
  5. Paul bunion
    Paul bunion
    Definitely have what you are seeing here too.
    This piece of red oak came off the stump on July 3 and was split the same day.
    Was 3164 grams. Now is 2229. 2229/3164 = .7044. Just a little less than 1/3 by weight.
    Another was 4550 and now is 3235 or .709.
    Pieces from July 30 have dropped about .20 by weight. So they are over halfway there in 5 weeks. But it does slow way down.
    Deacon and Backwoods Savage like this.
  6. Ronaldo
    Ronaldo
    Neat study!
  7. Backwoods Savage
    Location is a huge factor when drying wood.
  8. Ronaldo
    Ronaldo
    So true, wind and exposure to the sun do a lot of work.
  9. jatoxico
    jatoxico
    Long Island, NY
    Like to see you split a piece similar to your subject splits and throw the meter on it. Has been pretty dry.
  10. red oak
    red oak
    That's good to hear. I have been wondering how much my wood has been drying this summer because it's been really humid. I'm years ahead so I'm not worried but I just figured it would start drying more when it gets a bit cooler and less humid.
  11. Machria
    Machria
    Long Island, NY
    I can do that.. except.... well, it's raining harder right NOW than I have ever seen in my entire life! Unbelievable amount of rain today.....!
