The official Earthquake thread.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Dec 4, 2013.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Sorry for my ignorance but I don't understand spli case vs. clamshell..
    Ray
  2. the GOAT
    the GOAT Banned
    Copied from google a google search, but explains the differences well:
    "Clam shell" engines have the case split parallel to the crankshaft's rotation. They are the same design as snowmobile engines but the top of the crankcase is the same part as the bottom of the cylinder. The cylinder is not as easy to "tweak" because it is not it's own part, it's the top half of the crankcase and is holding the bearings in place. "Pro or split case" engines have the crankcase split perpendicular to the crankshaft's rotation. Cylinders can be shaved down to gain compression because they are their own part separate from the crankcase.
    raybonz likes this.
  3. the GOAT
    the GOAT Banned
    clamshell -- much harder to work on.
    'split case or pro' -- easy to pull the cylinder off of the case
    raybonz likes this.
  4. clemsonfor
    Unless your pretty feeble the 38 will work for what u want
    That's kind of why I got it and a truck box saw.
  5. the GOAT
    the GOAT Banned
    I checked the 4518 again, I had it tuned to 11,500. Turned in the H a bit to 11,900 and it sounded better to me. Though on the video it sounds like it's still a tad rich in the cut? (the limiter wouldnt let let me turn it up anymore)
    Doesnt cut much faster though, but it doesn't bog quite as easily... Only one problem 3/4 of the way through the log I smelled something burning. Stopped and saw that bark was smoking pretty good -- on a frozen piece of snow covered maple I dragged out of the snowbank this morning; Doh :eek: I've never had any saw burn a log quite that much.
    I'm done playing with it as is -- gotta save the rest of the log for comparison after a few mods.
    raybonz likes this.
  6. H 2 H
    H 2 H
    Try a different chain on those saws
    the GOAT and raybonz like this.
  7. the GOAT
    the GOAT Banned
    Here it is with a 16" .325 stihl RS chain, new out of the box (same type of chain as the 026 and an old husky small mount bar) 8 pin rim -- probably be better with a 7 but that's all I had handy.
    Knocked the time down to 35 seconds - from 54
    Next up is a muffler mod.
    DexterDay and raybonz like this.
  8. raybonz
    raybonz Moderator
    Carver, Mass.
    OK we're geting closer to comparing apples to apples.. That was respectable and more accurate comparison.. Looks like the EQ has potential..
    Thanks!
    Ray
  9. MasterMech
    It's kinda like you know there is a saw in there just waiting to be let out......... You just gotta figure out how!
    raybonz likes this.
  10. DexterDay
    This is a recommended chain from another place on the net.
    Oregon 91VXL62
    This should help a lot, along with a Muff mod, and a good tune (11,000 seems pretty conservative.) These come very fat from the factory.
    As for the 023/230 comparison. This Quake is built like a pro saw (split case as Mike from Maine described above). Much easier to work on and they seem to respond well to mods.
    Not a lot to the cylinder. The ports/transfers are of the simplest design. More pics later. :)
  11. raybonz
    raybonz Moderator
    Carver, Mass.
    If one of you saw guru's lived nearby I'd get together so you can let the saw out! Think this saw will be a bargain once you get it figured out.. Are all new saws equipped with cats these days or just Californian emission saws?
    Ray
    Pallet Pete and DexterDay like this.
  12. MasterMech
    Actually, most are not. They have gone stratocharged to avoid power-robbing cats. We are rapidly transitioning to electronic fuel metering as well. That helps keep a saw emissions compiant while keeping excellent power and throttle response.
    Say the word and I'm sure any one of us would buy a saw for you and ship it once modified. ;)
    Chvymn99, DexterDay and raybonz like this.
  13. the GOAT
    the GOAT Banned
    If a muffler mod'd quake runs with my stock o26 then I'll be impressed...
  14. MasterMech
    What if it takes a little more than a Muffler Mod? ;)
  15. the GOAT
    the GOAT Banned
    I'll do what it takes -but once you get past a muffler mod most don't want to go that far.. They'd be better off buying an 026 for 150-200.
    DexterDay, Boog and MasterMech like this.
  16. Boog
    Boog
    Where my spirit is free
    Niet!
    DexterDay likes this.
  17. raybonz
    raybonz Moderator
    Carver, Mass.
    :emb:
    Boog and DexterDay like this.
  18. H 2 H
    H 2 H
    If it does there something wrong with your 026 :)
  19. clemsonfor
    Isn't an 026 a 50cc? I wouldn't think a quake unported could ever run with a 26. Its still quality German saw next to a Chinese copy!
  20. raybonz
    raybonz Moderator
    Carver, Mass.
    Dunno about the 026 but my old 023 is made in USA..
