Building a room under an open deck so it is water tight?
Discussion in 'The DIY Room' started by don2222, Aug 15, 2015.
  1. don2222
    don2222
    Salem NH
    Oh yes
    That is why Pure Stock cars off the assembly line cannot beat a nice supped up modified! VaRoom!!!
  2. WildWildWest
    WildWildWest
    wyoming
    Although I am licensed for EPDM I prefer FiberTite. Obviously penetrations and seams can cause issues. EPDM uses seam tape and adhesive on seams. No seams would be best on your deck roof, looks like a 10 might have worked. Fibertite is a PVC membrane with proprietary product from Dupont, pretty much the best stuff on the planet, in other words it is the only jet fuel proof membrane. Anyhow the seams are heat welded and 660% stronger than adhered seams. Basically, I can provide up to a 30 year warranty, and yes it is watertight. I only brought up your flooring because Grace would have never ran ASTM, FM, or compatibility chemical reaction test of the asphalt product an a flooring product. I get it Don your tinkering have fun
  3. don2222
    don2222
    Salem NH
    Yes thanks for your comments. I just heard of PVC mil 60 membrane with RinoBond. Sounds like the good stuff!
  4. WildWildWest
    WildWildWest
    wyoming
    PART_1439946120444_IMG_20150714_132021620_HDR.jpg Jr High I am finishing up this week with Fibertite
    basod, smoke show, Deacon and 2 others like this.
  5. eatonpcat
  6. don2222
    don2222
    Salem NH
    eatonpcat likes this.
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    don2222 likes this.
  8. eatonpcat
    Oops...Didn't read enough to know that he was making an enclosed room! :picard:
  9. don2222
    don2222
    Salem NH
    Yes that is correct Smokey. If it was a simple addition, then a roof and shingles would work just fine. The big complication is the open deck above it. The roof of the room does have a nice slope to it and it is not flat and will not be walked on so it does not have all the potential failures of a flat roof. Commercial grade PVC membrane may have been the best choice but typically it is not used in a very small residential job.
    Here is what I have so far.
    Just a little shack to putter around in.
    What should I heat it with? :)
    basod and Deacon like this.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    A Smoke Dragon.
    basod likes this.
  11. don2222
    don2222
    Salem NH
    I have a choice of one of these 3 stoves I an currently refurbishing.
    1. Pelpro HHPP2BD
    2. Englander 25-EP
    3. Harman Advance with new Nickel Trim Kit.
    I wanted the Quad CB1200 but I sold it. :-(
    I would like a WiFi T-Stat on it.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    No you need a real smoke dragon something you could start a BBQ bizz on the side with. See BBQ with Franklin on PBS 's Create channel for ideas.
  13. don2222
    don2222
    Salem NH
    Hello
    As an extra precaution, we put Grace over the bolt holes that hold the joists down for the decking.
    See pic
  14. don2222
    don2222
    Salem NH
    Hello
    Still had water coming in when it rained! Putting in 2 windows stop it! :) See Pic Below
    Now all it needs is a door! ! !
    Click pic to Enlarge:
    Woodwidow likes this.
  15. don2222
    don2222
    Salem NH
    Hello
    Got some PolyGlass today to go on top of the Grace I&W to protect the grace before the deck boards go on.
    Is that a good idea?
    see pics
  16. bushpilot
    bushpilot
    Eastern Washington
    Oh man, we have been trying real hard to keep you from finding out. :whistle:
    :Yar:
  17. wildwest
    Sounds like a good idea! Anyone else? (WWW said good way to protect the Grace)
  18. CleanFire
    CleanFire
    Yeah, put something over that Grace before buttoning up the deck. Looking good Don!
  19. don2222
    don2222
    Salem NH
    Hello
    Polyglass is on over the 2 layers of grace I&W ! ! ! The light color pebble top on the Polyglass will not be harmed by UV rays and will reflect the heat. The Polyglass is tough stuff to cut!
    The Polyglass interlocks with a tab with the same special adhesive that Grace has. Grace goes up 14 inches against the house under the shingles.
    Some builders do a floating deck, but this is not floating, the joists are bolted into the 2x12s below the roof so it is stronger than a floating deck! The 2x12s below are tied to a ledger bolted to the house!
    See pics below. Click to Enlarge
  20. CleanFire
    CleanFire
    Now you don't have to worry about pressure washing the deck, beer spillage, or barbecue sauce ruining that beautiful Grace underlayment. :thumbs:
    What'cya gonna use the room for?
    Pellet stuff :grizz: :D,
    Beer & pretzel storage :pete:
    or Gun room when the Zombie Apocalypse starts? :saw: :heidi: :rootintootin:
    :popcorn:
    eatonpcat and wildwest like this.
