6.7 Powerstroke delete part 2.
Discussion in 'Chainsaws and Power Equipment' started by Drvn4wood, Aug 14, 2015.
  1. DexterDay
    Subscribed :)
    Drvn4wood likes this.
  2. mdavlee
    mdavlee
    That's what the programmer is for. I don't know about those but most of the others you don't need anything to plug back in any more.
  3. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Have to use a tuner to totally reprogram the truck. There's a few different ones but I went with the sct. Just plugs in under the dash like a Ford garage would do with a computer. 1439669761905.jpg
    clemsonfor and concretegrazer like this.
  4. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Correct. You have to tune the truck first and that will disable all dpf, scr, and egr sensors. I just taped the ends up and tied them off with zip ties. There are 12 total no longer in use between on the frame and under the hood. You can see the ones easily on top of the dpf canister now that it's out. 1439669931773.jpg 1439670181812.jpg
    mdavlee and concretegrazer like this.
  5. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    All done! Went well and everything works exactly like it should! Standing in front it's no louder at idle and the smoke is very minimal which is what I wanted.. Definitely has a rumble when you stand by the tip now that it didn't have before. The biggest difference is how loud the turbo is - sounds great! I'm looking forward to a few weeks of driving to see what kind of mileage gains I experience.
    The finished exhaust! 4" pipe back to the factory muffler. 1439670543407.jpg 1439670637188.jpg
  6. tree killer
    tree killer
    Central me
    Hope all works as planned. I didn't change my down pipe and GM doesn't use a muffler. Mine is a little louder but when you let off the throttle the turbo spins down and you definitely hear that. Need to invest in a whole exhaust system, it drives the wife nuts.
    clemsonfor and Drvn4wood like this.
  7. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Forgot the under hood pic of the egr plates and probe. The lower plate has an egt probe that we ran through the firewall where it connects with the tuner to monitor egt temps. 1439680062179.jpg 1439680111286.jpg 1439680183948.jpg
    jeff_t, concretegrazer and mdavlee like this.
  8. jeff_t
    jeff_t
    SE MI
    Wow, it's really busy in there.
    I had an '01 Dodge/Cummins, and I could almost climb in and sit down.
    Was it the 6.4s where they would pull the cab off for a head job?
  9. mdavlee
    mdavlee
  10. clemsonfor
  11. clemsonfor
    Is this thing not under warranty still?? Are you not worried of a warranty issue and having to put all that crap back on cause they will try and weezel out of the repair?
  12. mdavlee
    mdavlee
    With most of that gone the likelihood of a warranty claim went down about 75%.
    OhioStihl, jeff_t and Drvn4wood like this.
  13. clemsonfor
    I figured that but I think I would of still waited. He only has 35k on it.
    These new trucks eat injectors I have heard.
    A logger I know has a f450 thats not even 2 years old and I know his transmission just stopped and locked in a gear or something a few months back. Had to be towed to the dealer to fix. Only had like 40k miles on it.
  14. concretegrazer
    concretegrazer
    Southwest MO
    And good luck getting them to warranty them or so I've heard.
  15. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Yeah it's under warranty. I haven't had any issues with it whatsoever but the likelihood of having one went down by getting rid of that stuff.
    That is why I went with the egr blocker plates instead of the full delete. Much easier return to the stock setup.
    clemsonfor likes this.
  16. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I swear it was booby trapped trying to get to that lower plate. Every sharp clamp and fitting in there got my hand or arm..lol.. Not sure what all requires the cab lift, but when I bought this one the Ford dealer had the cab of a 6.7 raised for some motor work. My buddy that helped me has an 01 Cummins and he just shook his head at the under hood configuration of the 6.7..lol..
  17. mdavlee
    mdavlee
    I've put clutches and stuff on trucks with less than 1k miles. I used to be real into the performance side of stuff. I guess it's the same difference as tearing a new saw apart that's made 3 cuts at the dealer. I've only had 3 warranty claims in 14 years and around 550k miles in 10 different trucks. A few were daily drivers with up to 600 hp.
    cgraham1, clemsonfor and Drvn4wood like this.
  18. stackowood
    stackowood
    Oregon
    Interested to hear back on what your fuel mileage does. Nice write-up!
    I have a '99 7.3 so none of the DPF issues, but I suppose some day I could own a 6.7
  19. clemsonfor
    I was more thinking like my example of a transmission issue or say a cooling issue or something like that. They see the non factory parts and claim they can't be sure that this issue was not cause by that ...so they weesel out of the repair that way.
    I and you know thats not the truth but all a warranty is ...is them trying g to blame something on you so they dont have to pay for it. Esp in a case of aftermarket stuff.
    I hope you have a trouble free million miles out of it. Do t get me wrong. I just dont trust stealerships. :)
  20. mdavlee
    mdavlee
    I've had stuff repaired that wasn't something caused by it. A lot of dealers are more mod friendly now since it keeps the trucks out of their hair more.
