Pool lower deck replacement...
Discussion in 'The DIY Room' started by Chvymn99, Jun 21, 2015.
  1. Chvymn99
    I've gotta to replace the lower deck for the pool. The Uncle's wood finally rotted out. The good... He's got two outside beams of metal on the outside and three wood beams that help stabilize the interior. But I think I'll be adding a few more since he used 3" tongue & groove wood.
    Questions. How far on the spacing for like 2x6 on the bottom side? It's got about 16 foot span. Can I use 2x6 and be fine with a finished surface?
    The Aunt wants to piece it in. But I'm thinking that I'm going to replace all 16' at one time. I'll try to get posture tomorrow....
    Eric VW, WaddleRemodel and wildwest like this.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    The 2x6 joists are spanning 16'?
  3. schlot
    schlot
    NW Iowa
    Any pics? They would make it easier to help.
    Eric VW, wildwest and Chvymn99 like this.
  4. wildwest
    Are you slumping Chvymn99 ? Stand up straight young man!
  5. Chvymn99
    I'll get them tomorrow...I know pictures are worth a thousand words...
    Eric VW, schlot and wildwest like this.
  6. Chvymn99
    :cheers:... Enough said...:drunk:.. Fathers Day... :yes:
    Eric VW, concretegrazer and wildwest like this.
  7. wildwest
    I have no deck experience though other projects I have repaired by piece in the past I wish I had done the full replacement. Happy Father's Day friend :)
    Eric VW and Chvymn99 like this.
  8. papadave
    Wondering the same.
    Pretty skimpy, unless you go 12" OC or something to beef it up.
    My IS heats my home and Eric VW like this.
  9. Chvymn99
    I'll measure tonight. I'm already planning on closing that gap on down just want to make sure its the right distance the first time. But the Uncle worked construction and got this tongue and groove it looks like 3x6 and it was untreated. And it was fine until wood rot...
    Me either, that why I'm seeing what others have thoughts on. I just cant see replacing only 3/4 when another 4 ft will do it all...
    Eric VW likes this.
  10. ironpony
    ironpony
    Mid Ohio
    3x6 T&G would probably span that, 2x6 no way
  11. ironpony
    ironpony
    Mid Ohio
    safe side 1" of board for 1' of span. 2x6 6 foot span.
    eatonpcat and Eric VW like this.
  12. Chvymn99
    Here's a drawing...
    Eric VW likes this.
  13. ironpony
    ironpony
    Mid Ohio
    2x6 might be a little spongy on that span, split it to 2' spacing and good to go.
  14. schlot
    schlot
    NW Iowa
    So you have three steel beams and two wood beams, and you will be putting new beams in between each? So the distance between beams (new or old) will be 2' rather than the existing 4'?
  15. schlot
    schlot
    NW Iowa
    ....and the 2"×6" x8' will be the decking material?
  16. Chvymn99
    Yes and yes... She's wanting to do it in the least amount as possible. Otherwise I'll be putting money into from my pocket... Unless you all think like decking boards would be suitable for this.
    Eric VW likes this.
  17. schlot
    schlot
    NW Iowa
    I think you are on the right path. 4' span for 2x deck boards will result in a lot of deflection and bounce. You should be happy at 2'.
  18. Chvymn99
    :thumbs:... Thank you!
    Eric VW and schlot like this.
  19. schlot
    schlot
    NW Iowa
    You bet. What were you thinking of using for the new beams?
  20. Chvymn99
    Here is the degraded stage of the deck. And the underneath beams...
