Help me identify this thing!
Discussion in 'Chainsaws and Power Equipment' started by MasterMech, May 1, 2015.
  1. MasterMech
    That's my hand in the vid. It was attached to a fellow Hoarder's 353 in Germany. Unfortunately due to the language barrier (He's German) I think we got the product name confused. The name he gave me was Kolibri/Colibri.
    Has anybody else seen this thing or know where to get one?
  2. Grizzly Adam
    Grizzly Adam Guest
    Are you talking about that nipple bolt thingy?
    Eric VW likes this.
  3. Cut4fun
    Cut4fun
    OHIO Redneck
  4. MasterMech
    The whole length gauge. Of course the nipple bolt and the couple are what make it so slick.
  5. Grizzly Adam
    Grizzly Adam Guest
    I think it shows that I didn't watch the video, at work :whistle:
  6. MasterMech
    Horkn, Eric VW and Canadian border VT like this.
  7. w8ye
    w8ye
    Mansfield, Ohio
  8. clemsonfor
    So you went to germany?
    Horkn and Eric VW like this.
  9. w8ye
    w8ye
    Mansfield, Ohio
    Would be better to make your own?
    A barrel nut and a piece of old fishing rod?
    The quick Stix is notorious for the rod breaking at the nut from vibration the first time you start the saw up?
    clemsonfor, Cut4fun and Eric VW like this.
  10. Jon1270
    Jon1270
    Pittsburgh, PA
    Maybe if you were to weld an air hose fitting to a stock bar nut...
    Anyhow, if you find a source, I want one.
  11. Bret Hart
    Bret Hart
    Central NY
  12. pantelis
    pantelis
    Europe
    http://www.grube.at/nestle-ablaenghilfe-kolibri-10-320-25-variation.html
    http://www.grube.at/kolibri-zapfenmutter-unverlierbar-10-320-01.html
    http://www.grube.at/ablaenghilfe-cut-control-10-310-25-variation.html
    Best regards
  13. pantelis
    pantelis
    Europe
    the source are posting
    Pallet Pete, Horkn and Eric VW like this.
  14. pantelis
    pantelis
    Europe
    A walk to the Waibligen is very good for the health ............. i think
  15. haveissues
    haveissues
    Hudson Valley
  16. Jon1270
    Jon1270
    Pittsburgh, PA
    Well, there it is. Pricey, and doesn't seem to be available outside Germany. So sad.
    Eric VW likes this.
  17. MasterMech
    Still here. Not going to be here long enough to order one unfortunately.
    That's certainly not convenient but it's not an impossible barrier either.
    What makes it work is the tight fit between the coupler and the nipple. An air hose type disconnect would fail rapidly from vibration as they rely on an O-ring and pressure to maintain the "tight" connection.
    pantelis and Shawn Curry like this.
  18. Jon1270
    Jon1270
    Pittsburgh, PA
    What part of it do you think would fail? The O-ring? Why would that matter?
  19. MasterMech
    The amount of play in those fittings would let the whole thing tear itself apart from vibration I would think.
  20. Jon1270
    Jon1270
    Pittsburgh, PA
    Maybe so. The German model looks very nicely made, but in the US I'd be worried about losing the bar nut end of it in a field somewhere and then being unable to replace it.
    MasterMech and Shawn Curry like this.
