Top cover material experiment
Discussion in 'The Wood Pile' started by NH_Wood, Apr 18, 2015.
  1. NH_Wood
    NH_Wood
    Ran out of my rubber roofing squares for my stacks, so decided to give another material a shot. Took 4 empty bags from my chicken feed, cut the top and bottom flush and cut one side to make a flat sheet. Overlapped the sheets on a top pallet, with a lot of overlap between the sheets and shingled down angle toward the fence. Stapled down along tops and sides pretty well so it wouldn't flap in the wind. Pretty tough material and will be fun to see how long it holds up. I'm guessing the Sun will break is down and wind will eventually lead to tears, but only took a few minutes to try. Cheers!
  2. red oak
    red oak
    That looks like a pretty good idea. I have a lot of those bags and I usually wind up just burning them or throwing them out - I'll have to try your idea.
    Eric VW, fox9988 and NH_Wood like this.
  3. NH_Wood
    NH_Wood
    Sounds good - we can compare how long they last. I think the key is getting them stapled tight so the wind can't flap the edges - I'm sure it would rip from the staples in no time if the wind could move it. Free, so why no try! Oh, they are also worth keeping as sheets to lay down to catch oil, etc. Cheers!
    Eric VW and red oak like this.
  4. fox9988
    fox9988
    NW Arkansas 72717
    Good idea. Those bags are pretty tough and I've got lots of them.
    Eric VW and NH_Wood like this.
  5. jetjr
    jetjr
    Pa/Md line
    I use them when I run out of tarps too. I just cut the bottom string and up the side. I just use uglies to hold them down.
  6. NH_Wood
    NH_Wood
    Do you have single rows? The top of my stacks are uneven enough that if I didn't add a pallet to the top, the rubber roofing or these bags end up forming pools of water that inevitable runs into the stack - I've started placing a pallet on the top to keep level and angle to let water run off one side - had made a great difference. Cheers!
    Stinny and Eric VW like this.
  7. jetjr
    jetjr
    Pa/Md line
    No I stack in rows of three or four. I usually use the bags for if a tarp isn't long enough. The pallet idea is a good one. I usually try to stack one end higher and as flat as possible at the top.
  8. My IS heats my home
    My IS heats my home
    Albany, NH
    Very flashy...glad you found a good use for the bags and it worked.
    Eric VW likes this.
  9. Woody Stover
    Woody Stover
    Southern IN
    You burn plastic??
  10. red oak
    red oak
    No - the feed bags I get are either paper or plastic. I burn the paper and throw out the plastic.
  11. bogydave
    Enviro friendly multi use recycling :yes:
