Muffler Modification?
Discussion in 'Chainsaws and Power Equipment' started by Chvymn99, Nov 10, 2013.
  1. the GOAT
    the GOAT Banned
  2. clemsonfor
    Yea I guess my description was not dead on.
  3. Chvymn99
    Boy those are some buggers to get off there. I'll probably play with it in the morning. I got one partially off I can see the screw down there. So that's a positive. Thank you for the help guys.
  4. clemsonfor
    There pretty easy to pull off? Take a screw driver and pull them partially out, kind of like it sounds you have done one the one. Then grab it with forceps or needle nose. The pull right out??
    Chvymn99 likes this.
  5. MasterMech
    Drywall screw. ;).
  6. Boog
    Boog
    Where my spirit is free
    Amazing tool .................. that's what I ended up using too! Also I think you want the limiter turned all the way counter-clockwise so the tiny little plastic tab lines up with a slit, then pull out. Seem to recall that from memory, because turning the drywall screw in would turn the plastic limiter back clockwise...............
    Chvymn99 and MasterMech like this.
  7. MasterMech
    The actual tool to pull those is just a small machine thread screw end with a screwdriver handle. And left hand threads.;)
    mdavlee and Chvymn99 like this.
  8. clemsonfor
    The 2 sets I pulled i did not have trouble with pliers? And I do not have a huge selection of tools. Better than most but not huge.
  9. MasterMech
    Take a closer look at this photo and decide if pliers are going to get it done.
    I've pulled a few limiters myself ya know. ;)
    Boog and Chvymn99 like this.
  10. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Wrong! It took me two hours of heck to get the darn things out. I ended up using a small screw driver taking the top cover off the saw and tapping very gently until they started to jiggle a little. Then I took a screw and a drill then proceeded to put three screws in before they came out. No way they where coming out with needle nose pliers not gonna happen.
  11. clemsonfor
    Maybe I was lucky? I tap them like pete. But I'm not lieing it took me all of 2 mins to pull them on the ms650.
    I guess I was lucky. 3-4 yrs ago when I rebuilt the 390 Carb I pulled those out with a tiny screw driver prying them and grabbing I think. Was my first time so was not sure how to pull them. I may of spent 10 mins on them??
    Y'all just disregard me and listen to the more experienced guys.
    Pallet Pete likes this.
  12. Chvymn99
    Maybe you were, or I just have a stubborn set. But keep posting, you've added some good input. And I still haven't started to tune it yet.
  13. Pallet Pete
    Ovid
    Clem I'm not calling you a lier sorry about implying that. Your a good guy! A little too honest at times :rofl: :lol:
  14. clemsonfor
    Well my wife says that's my fault. I will tell you kike it is. I will call your BS to your face, she hates it cause I will disagree with anyone I think is wrong. Not saying anything here is BS but u see my point. I mess up I'll own it. Back to thread.
    fox9988, Chvymn99 and Pallet Pete like this.
  15. clemsonfor
    OK not sure where my text went but.....
    Here I am posting how I did it. Not for a who's right thing but if it helps someone remove them in less than 2 hours, great!
    This is the limited cap out of my 650 and the very set of pliers I used. Screwdrivers are pretty self explanatory so I'm not posting them.
  16. Chvymn99
    Interesting looking cap though, with just that bump as the limiting factor. If I'm looking at it correctly.
  17. clemsonfor
    Yes if u cut that small tab off and reinsert it you van get the full range of motion out of screw and I think it was mom said that it helps hold the setting and not vibrate out of adjustment.
    Edit:
    Haha That was so funny I left it. Should be ..van equals can. Mom should be MM. Stupid autocorrect.
    Trilifter7, MasterMech and Chvymn99 like this.
  18. Pyroholic
    Pyroholic
    mid michigan
    You sir, have a cool mom.
  19. Chvymn99
    Well here is Muffler Mod.
    This guy came off:
    Looking at this now:
    Pallet Pete, fox9988 and MasterMech like this.
  20. clemsonfor
    Never seen that other piece around the screws come off?
