I finally got a Wood splitter
Discussion in 'Chainsaws and Power Equipment' started by 94BULLITT, Apr 4, 2015.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    I have been looking at wood splitters for a long time. I did not like the way that most of the box store splitters were laid out. The axle is in the way on most of them when it is used horizontally. Commercial standalone splitters where too much for no more than I would use it. I had kicked the idea around of getting a splitfire 3203 or 3403 to run off the tractor. The biggest problems with this idea was if I wanted to cut wood somewhere else the tractor would have to be moved with the splitter. I was looking at Harbor Freights website and saw they had a splitter. It is pretty much the same splitter that Northern tool sold under the Power Horse name. I thought the pictures of it looked like it was pretty good. I watched videos of it on Youtube and it looked like it worked good. I could not find anybody saying anything bad about them. I also researched the Predator engine. It seems they have quite a following. I found mostly good things about them too. I called the 10 closest stores to me and none of them had one in stock. Some of them told me to call back on Thursday or Friday when they got their stock order. I did this for two weeks and no one got one in stock. I really wanted to see what I was buying but I went ahead and took a gamble on it and ordered it. I ordered it last Saturday and I got it Thursday. I put it together Thursaday, everything went smoothly. It started on the second pull. So for I am really impressed with this splitter. It is an extremely good value.
    Here is the crate the splitter came in, it had a box around it.
    I did a walk around video of the splitter.
    My first modification to the splitter, a hourmeter/ tach.
    Some wood split with it.
    raybonz, Doug, Hammy and 22 others like this.
  2. HDRock
    Were you able to get 20 percent off that puppy?
  3. 94BULLITT
    94BULLITT
    I looked everywhere and I could not find a 20 or 25% off coupon that is valid and could be used on a predator gas powered product. The newest coupons I could find that did not have that exclusion were January 2015.
    wildwest, Horkn and HDRock like this.
  4. HDRock
    Here is an idea for you to roll the big ones up there.
    Courtesy of basod
    raybonz, KsKent, Pallet Pete and 13 others like this.
  5. HDRock
    I know they do exclude some things from those coupons.
    That's a 20 ton right?
    wildwest, Horkn and 94BULLITT like this.
  6. 94BULLITT
    94BULLITT
    Thanks for showing me the pic of the log ramp. I am thinking about adding a log lifter to it. Yes it is a 20 ton splitter.
  7. HDRock
    Wow his splitter and yours look about the same
    wildwest, 94BULLITT and Horkn like this.
  8. HDRock
    That TAC monitor is cool how much did cost ya?
  9. 94BULLITT
    94BULLITT
    raybonz, wildwest and HDRock like this.
  10. Horkn
    I know the one from HF is the same, but a different color than at least one other splitter. I read all the reviews on them. I was pretty impressed, and if I was to buy a new splitter, this would definitely be one of my top choices.
  11. HDRock
    I have a Harbor Freight 7 ton electric I have been splitting all my wood for the last three and a half years
    raybonz, savemoney, Brad38 and 3 others like this.
  12. 94BULLITT
    94BULLITT
    I just watched a video of one of those on youtube. It was doing pretty good.
    wildwest, HDRock and Horkn like this.
  13. HDRock
    Oh , it does real good , shag bark hickory I split up last week
  14. Stinny
    Nice splitter! I like... right off the bat... that the engine and "stuff" are waaay away from where all the work happens. I like my TB splitter a lot, but the engine is right in the line of fire... :picard:
    raybonz, HDRock, wildwest and 3 others like this.
  15. basod
    basod
    Mount Cheaha AL
    We added that stub of stainless pipe to the foot on the engine side of the splitter to keep the stray split from making it's way onto the gas tank.
    Other modification was addition of some zirc fittings along the beam to grease easier.
    the beam on your splitter extends out the front, and has a longer tongue - you'll bend it eventually on a big round so use the jack when working on bigger stuff
  16. 94BULLITT
    94BULLITT
    Thanks. The lay out of the splitter is very nice. The engine is out of the way of the work area but a split could still fall on it. I plan on making a guard/ protector for the engine.
    I thought the pipe on yours was there to protect the engine. I like the idea of grease fittings on the beam.
    How long have you had your Powerhorse splitter? How much have you split and how is it holding up? I know at a quick glance our look alike but there are a lot differences.
    basod, HDRock, wildwest and 2 others like this.
  17. Gasifier
    Nice splitter there 94bullitt! Good work, :yes: and keep us posted.:popcorn:
    raybonz, HDRock, wildwest and 2 others like this.
  18. 94BULLITT
    94BULLITT
    Thanks, I'll update this thread with any modifications I make to the splitter or any repairs I have to do.
    raybonz, savemoney, basod and 3 others like this.
  19. bogydave
    Looks like it's earning it's keep
    Already made a nice pile of firewood. :yes:
    raybonz, splitoak, 94BULLITT and 3 others like this.
  20. Woodrat1276
    Woodrat1276
    Ky
    That thing looks like its a nice unit like to see it in action
    raybonz, Horkn and 94BULLITT like this.
