Stihl RM or RS
Discussion in 'Chainsaws and Power Equipment' started by Certified106, Mar 26, 2015.
Which Do You Prefer?
  1. Stihl RM chain
    8 vote(s)
    15.1%
  2. Stihl RS chain
    30 vote(s)
    56.6%
  3. Other
    5 vote(s)
    9.4%
  4. Have both but use them for specific purposes
    10 vote(s)
    18.9%
  1. Woodchuck
    Woodchuck
    Southeastern Ohio
    Can someone post some pics of the different types (ie: RM vs RS) ? :ithappened:
    clemsonfor likes this.
  2. MasterMech
  3. Woodchuck
    Woodchuck
    Southeastern Ohio
    Kind of hard to see the difference from Stihls pics. The RS is full chisel?
  4. Elderthewelder
    Elderthewelder
    Washington State
    yes rs is full chisel, rm is semi chisel. i just bought 2 rmf (semi chisel full skip) chains as all of the stuff I cut is scrounged and has been in the dirt and I am hoping the chains last longer between sharpenings
  5. bogydave
    closer up:
    RS
    RM
  6. bogydave
    Same cutter on the RS3 & the RM3
    Just have a hump on the link that comes up when the chain goes over the nose of the bar to reduce kick back potential.
    Work good for liming & most cutting, works for bore cuts too, just not take as big of a bite.
  7. Elderthewelder
    Elderthewelder
    Washington State
    and well have the green color coded link
  8. bogydave
    Old RM with safety hump . safety chain ,
    RM3 green chain now. different safety hump design now too.
    Shawn Curry and StihlHead like this.
  9. bogydave
    That old chain shows why I started hand filing my own.
    Took several to a local sharpener & got back burred & burnt cutter tips.
    over heated the tips & took the temper out ,
    ground them down fast & has bad burrs
  10. StihlHead
    StihlHead
    The wild west
    That is what I file all my chains at: 30 and 0 offset. Some Stihl chain comes at 35 but I cannot get my files in there that steep. I always file at a 0 degree offset. What is attempting to be described above in some posts is called the offset angle.
    $ooline likes this.
  11. StihlHead
    StihlHead
    The wild west
    That is RM2 in the photo there. Semi-chisel with the big-azz safety rakers. They do not make that any more. They make safety rakers now that overlap the cuter rakers on the flats and open up when they go around the tip to increase the raker length and hence the safety aspect (less kickback that way).
  12. bogydave
    New it was old , RM2 eh. Not sure how long I've had it or where I got it :)
    Still usable in a pinch, but burned cutter tips will prob dull fast.
  13. StihlHead
    StihlHead
    The wild west
    I have several loops of it. Stihl saws here used to come standard with RM2. I use it for cutting potential naily yard trees, fence posts and the like. They used to make an RM with the same cutters w/o the safety straps, and that was good stuff. I still have some of that. The new RM is what was called RMC. The guys at Stihl like to really confuse things, especially when it comes to chain.
  14. dgeesaman
    dgeesaman
    Elizabethtown, PA
    ...so... how much faster does full chisel cut? If changing / sharpening loops is not a big deal, is the semi-chisel still the most effective solution?
  15. Certified106
    Certified106
    In The Hills
    I really can't stand that safety chain at all. I was cutting with a friend one day and grabbed his freshly sharpened saw and with the safety chain on it still felt dull to me.
    I tend to run my rakers a bit lower than they should be also and feel I get a better bite on the log as long as the saw has enough guts to handle it. It can be a fine line between better and grabby but I am getting it dialed in pretty well.
    Shawn Curry and DexterDay like this.
  16. Firewood Bandit
    Firewood Bandit
    Since I have 2 unopened 100' rolls of 3/8ths Oregon LGX and half a roll of spun up ones, I think I'll stick with the LGX. (got an insane price on it). :whistle:
    For skip, the JPX can't be beat. :dex:
  17. bogydave
    For me & cutting 10 cord +/- per year,
    I find the LPX (safety ) to cut as well as the LGX pro.
    Might be a little difference, but not real noticeable for my type of cutting.
    Price being an issue, I too like the LGX / LPX
    Additionally LPX is easier to find here.
    My last LGX was online order.
    RS is good chain too, on the shelf at the Stihl store. higher cost though,
  18. Firewood Bandit
    Firewood Bandit
    I wouldn't call LPX safety chain. The ramps before the raker reduce vibration and are way lower than the depth gauge so it really doesn't slow the chain down. I like LPX a lot in .325 where you do a lot of limbing. I run LGX in 3/8ths. This ramps makes JPX much smoother than JGX, (J designation means skip)
    Sunfish and SAWMIKAZE like this.
  19. StihlHead
    StihlHead
    The wild west
    In theory, full chisel square filed is 10% faster than full chisel round filed which is 10% faster than semi-chisel round filed. In dirty conditions semi-chisel is the better choice, as it will stay sharp longer. Full chisel will just get dull too fast.
    Madsens has good information on a lot of these issues here http://www.madsens1.com/muu_barchain.htm
  20. Fishnuts2
    Fishnuts2
    SE, MN
    So far, I think the loops that I have of RS and RM, have shown two things. The RS is much faster, and finds nails and dirt quicker than RM.
