MS 170 perk up/mod
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Mar 11, 2015.
  1. WeldrDave
    As some of you know, I just prunned my trees this past week and I used my 170. I don't have a complaint at all and it's a great little saw, but would a muffler mod be worth doing on it to get a little more uumph...?
    I realize you not gonna get a massive change in it for a trimmer saw but has anyone approched this?
  2. Chvymn99
    The only thing that I could think of negative on this is does it have a adjustable carb? That was the one issue with my 180... But Honeyfuzz but a adjustable on it.
    Also make sure to keep the screen on the spark arrestor clean.
    WeldrDave likes this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    Put a Walbro WT-215 carb on it then mod the muffler. It will really wake it up.
  4. clemsonfor
    Need an adjustable carb.
    That and advancing the timeing you will have a screamer.
  5. 94BULLITT
    94BULLITT
    Here is my 170 after a ignition timing advance.
  6. clemsonfor
    What negative if any effects does advancing the timeing have on a stock saw or even muffler modded saw?
    If the benefit is this good why dont the manufactures just time it like that to start?
  7. 94BULLITT
    94BULLITT
    With the timing advanced the saw will kick sometimes when you start it. The saw cranks a little harder now too.
    MasterMech and WeldrDave like this.
  8. clemsonfor
    I can see hard starting to be a huge negative for a manufacturer. They want things that start easy.
  9. 94BULLITT
    94BULLITT
    They probably also having the timing set conservative so if someone runs old gas they won't burn a piston.
    WeldrDave and prell 73 like this.
  10. WeldrDave
    Good stuff Guy's!!! I'm not a super mechanic, but I can get it done. pound for pound, that is a "super" little saw! When I was up in the bucket holding it with one hand, I was saying to myself… Boy I wish It would cut faster :whistle: Thanks for the input, it gives me some ideas!
    94BULLITT likes this.
  11. WMW0505
    WMW0505
    Lexington, KY
    Chain goes a long way on these little guys too. What are you running?
    Hint: anything other than yellow chisel chain is the wrong answer.
    WeldrDave and clemsonfor like this.
  12. WeldrDave
    It's the factory green safety chain...:emb:
    WMW0505 likes this.
  13. WMW0505
    WMW0505
    Lexington, KY
    Grab a loop of yellow chisel chain the next time you find yourself at the dealership.
    I use semi chisel on my other saws due to dirty wood and the occasional unintended ground strike. I normally only use my 180c for limb work so I have no worries about dirt.
  14. 94BULLITT
    94BULLITT
    I don't think you can get yellow chisel chain from stihl in .043."
    rookie1 likes this.
  15. WMW0505
    WMW0505
    Lexington, KY
    You may be correct. I run 0.050.
    94BULLITT and clemsonfor like this.
  16. FarmHand78
    FarmHand78
    South East Iowa
    I've got a 017/MS170 Frankensaw, It's a 017 chassis with a MS170 jug, has an aftermarket fully adjustable carb and muffler modded. I'm running 3/8 picco in .043 Stihl 61PMM3 chain on a 14" bar. The little thing just rips through wood. I wouldn't get to carried away with the chain, I think it could get to aggressive for the little saw that it is. I love the exhaust not the mad little bumblebee has, like a wanna be big saw.
    rookie1 likes this.
  17. FarmHand78
    FarmHand78
    South East Iowa
    Drvn4wood, 94BULLITT and prell 73 like this.
  18. Eric VW
    Great little saw there, 94BULLITT,
    I must read more about ignition timing. Besides a search of the forum, can anyone tell me the ins and outs of performing an adjustment to the ign. timing?
    Thanks,
    Eric VW
  19. clemsonfor
    I am thinking you have to cut the key off and then just turn the flywheel a bit and tighten it back down with lock tight.
    Least thats what I have read here and on AS. But I am sure the other guys can tell you better.
  20. Eric VW
    That sounds like NOT fun if ya screw it up!
    Who else can share their experience/how to- in advancing ignition timing.
    Eric VW
