Your favorite moisture meter and temp gage/probe
Discussion in 'Modern EPA Stoves and Fireplaces' started by TurboDiesel, Nov 30, 2013.
  1. TurboDiesel
    Hi Guys
    Was thinking about a new thread just for your input an moisture meters, temp gauges, temperature probes, for stove top, on the flue, in the flue or anything that would go in this category.
    What's your favorite brand?
    Where you bought it?
    Price?
    Accuracy?
    What to stay away from?
    Maybe even make it a sticky for a one stop shopping ?
    What do you think?
    Thanks
    TimK
  2. TurboDiesel
    If there is already a thread on this subject can you point me there
  3. BrianK
    BrianK
    West central PA
    Joe Seaton likes this.
  4. DaveGunter
    DaveGunter
    I think most of the surface temp gauges can vary a lot from gauge to gauge, even between exact same model/manufacturer. They can also be affected greatly by airflow, the stovetop gauge on my 30 reads about 150 low when the blower is on. I use the gauges only as a rough idea/quick glance, but have gotten used to knowing what the reading really is as compared to an IR gun. IR guns are so cheap and accurate it seems silly not to have one.
    HDRock likes this.
  5. Well Seasoned
    I have been extremely happy with condar's line if thermos. Both the stove top and flue probe has been more accurate and durable than the Rutlands. I have been happy with the cheapo harbor freight moisture meter and the Ryobi ir meter would be nicer with a hight temp reading than the 650 I get.
  6. BrianK
    BrianK
    West central PA
    I picked up the gun style Harbor Freight IR thermometer last Saturday for around $20 on sale with the extra 20% off coupon. I checked it on boiling water and it read 213 and it goes up to 1000 degrees. That's accurate enough for my needs.
  7. DaveGunter
    DaveGunter
    Exactly. How does the IR gun compare to your gauges?
    I would like to know if there is a probe type available for single wall pipe. I have heard many times that the surface temp on single wall is roughly 1/2 the gas temp, someone must have measured that at some point to make that generalization. How can you measure gas temp on single wall?
  8. DexterDay
    I have a Condar probe for my double wall, but have a Tel Tru stove top mag thermo and love it. By far the most accurate I have had. Compared to my IR gun, the Tel Tru has been the closest. With that said, the Condar stove top was the next closest, but read about 50* under.
  9. fox9988
    fox9988
    NW Arkansas 72717
    I have:
    General MM from Lowes- I've bent the probes trying to stab it full depth into oak and straightened them many times. They'll eventually break.
    General IR from Lowes/Woodstock stove top/Lowes stove top(Imperial?)- All very close to one another.
  10. charlie
    charlie
    Schoharie, NY
    PTC surface gauge and Tempoint Bacharach flue probe.. Both of my stoves use these gauges.
  11. TurboDiesel
    do you leave the temp probe in the flue all the time?
  12. charlie
    charlie
    Schoharie, NY
    Yes, the probes stay in both stoves all the time... Easy to see the needle from across the room.. Plus the probe can be calibrated in boiling water..
  13. DaveGunter
    DaveGunter
    Can you use that probe meter on single wall?
  14. Well Seasoned
    You can, but it would be more ideal to just use a magnet type, saving yourself from drilling any holes. The magnetic type would be nearly identical in temperature.
  15. charlie
    charlie
    Schoharie, NY
    Yes you can use it on a single wall as well... Here's where I first use one of these probes , on my single wall pipe on my Paxo 60 gasification boiler.. They are dead nuts accurate and you can also check them by simply putting the probe in boiling water, should read 212 degrees. If nit you can adjust the probe to read correctly.. BrianK just brought one on here and said he tested as new in boiling water and it was right on.. What ever works for you...
    BrianK likes this.
  16. DaveGunter
    DaveGunter
    I'm confused. I thought a magnetic surface temp thermometer reads about half what the actual gas temp is on single wall.
  17. DexterDay
    If I was to replace my probe, this probe is what I would have. As for surface, the Tel - Tru or PTC would be my top picks.
  18. HDRock
    Are you confused? a magnet mount and a probe will not be the same temperature
  19. HDRock
    I bought one of those to, because the other one I had only went to 625
  20. HDRock
    I have a general tools moisture meter and a harbor freight, moisture meter.
    They read the same, but I like the harbor freight because it powers up fast and fits in pocket nice
