MillerModSaws and the PS-7910
Discussion in 'Chainsaws and Power Equipment' started by millermodsaws, Feb 16, 2015.
  1. millermodsaws
    millermodsaws
    20150305_165619.jpg Both saws back together 1 at 27° bd and 1 at 29° blowdown. Headed to the test log.
    Chvymn99, DexterDay, mdavlee and 2 others like this.
  2. Moparmyway
    Moparmyway
    New York
  3. rburg
    rburg
    TN
    Did you decide which dolmar model you are doing next?
  4. millermodsaws
    millermodsaws
    No i havnt. I have that posted on AS too. Last I looked the 6100 was winning there and the 5105 was winning here.
    mdavlee likes this.
  5. rburg
    rburg
    TN
    I like the sound of the 6100, but I enjoy build threads whichever model is done.
  6. mdavlee
    mdavlee
    And where's results, videos, something???????????????????????????????????????????????????????:hair:
    :popcorn::cheers::popcorn::drunk:
  7. Moparmyway
    Moparmyway
    New York
    Yeah ............ I am with mdavlee on this ............... these last 2 hours is like 2 full days !!
    (Only kidding, I just got back in from clearing 2 big properties of snow - we got 10 inches dumped on us today)
    That Hardline tach on my snowblower is working out great !!!
    concretegrazer and mdavlee like this.
  8. millermodsaws
    millermodsaws
    Ok here they are and give me some opinions. These saws run very very close but you can tell the difference. The 27 blowdown will produce around 400 more RPMs in the wood it really likes 11800 with a light hand. The 29 blowdown likes 11400. But here's were I started a bad thread on AS that was torque vs chain speed. The 29 blowdown can be dogged a little harder so cut times are all in the same. If you lay the saw on the wood and just let it cut. No dogs what so ever the 27 bd wins if you apply just a little dawg the 29 blowdown wins. I cut probably 20 ft of tree in cookies and still couldn't decide which one I likes better. I don't think you can lose with either. Both would produce a consistent 14-15 sec cut. Just adjusting to each saw took a couple cuts. I'm thinking maybe a 102/28 would give and take the best. So hammer away boys and let me hear what your thinking. I'm going to leave both saws as they are. Play with the timing and see if I can get a few people to run them and see what they think. I think I'm down to where it's operator preference.
  9. mdavlee
    mdavlee
    I figured that would be about the conclusion. I'll have one here next week and I hope to play with it this next month. I'll probably go 101 128, 79-80.
    millermodsaws likes this.
  10. millermodsaws
    millermodsaws
    vid was kinda crappy I was being a little to heavy handed at first but this is the 102/131/80 saw.
  11. DexterDay
    I am no builder, so the numbers I can't judge.
    But I like that last video. A lot! ! ! Sounds great and you are really digging in! !
  12. millermodsaws
    millermodsaws
    The 102/129/80 (saw 1)
    Moparmyway likes this.
  13. DexterDay
    After watching and hearing both? I like Saw 1:)
    As you said, it holds some more RPM in the cut. :thumbs:
  14. Moparmyway
    Moparmyway
    New York
    I like the 102/131/80 .............. on a 32" setup, this saw should really shine above saw #1
    concretegrazer likes this.
  15. rburg
    rburg
    TN
    I like the log lift you use. Every chainsaw user needs one of those.
  16. Chvymn99
    Nice...:thumbs:....
  17. millermodsaws
    millermodsaws
    Ok boys I want to add this in. I still have to do my ignition advance trials but this pair of saws is just about done. Fin460 has spoken for one but the other one is for sale. This first pair of saws is going out the door for $850 pho. Each will have probably 3 tanks tops ran threw them. I thought I'd offer it to the ones following the thread here and on AS first. If i havnt thanked you guys. Thank you for hanging in my slow build process and all the opinions as we have went threw.
  18. concretegrazer
    concretegrazer
    Southwest MO
    That's what I'm thinking as well.
    Both look to be good runners. Nice work!
    Chvymn99, mdavlee and Moparmyway like this.
  19. millermodsaws
    millermodsaws
    Ok here's the flywheel off. On the built in keys it's very hard to measure and say file .050 off and it will give u 5°. So the arrow points to the side I file from. This allows the flywheel to be rotated ccw
    mdavlee likes this.
  20. millermodsaws
    millermodsaws
    I put my piston stop in and rotate the engine ccw till it hits. I mark the flywheel and the cases at this point before I file. I then take some off and put the flywheel back on loosely and remark the cases while holding it in the counter clockwise position. I then use my degree wheel and move it between the marks to see how much I have advanced it. I was aiming for 5° and got a little happy. These marks are 6° apart. You can also mark 5° before you start and file check file check. You get the idea. Lol.
