Recommend an Affordable Humidifier
Discussion in 'Modern EPA Stoves and Fireplaces' started by Thundar, Feb 17, 2015.
  1. Thundar
    Thundar
    Southeast Ohio
    Thanks for all your advice!
    wildwest and HDRock like this.
  2. TurboDiesel
    we boil two pots on the electric stove for a few hours when its really cold outside
    also a big soup pot on the woodstove 24/7.
    and my cpap machine uses water. thats keeps me from drying out year round
  3. wildwest
    :popcorn:
  4. savemoney
  5. savemoney
    I have bypap, sit it on high every night no matter what. Only had one cold in the past two years!
    TurboDiesel likes this.
  6. wildwest
    How do you humidify your home?
  7. savemoney
    I have a cheap humidifier from WalMart. Just keep fresh filters in it and it works fine. Also, I vented the dryer into the utility room. When the humidity goes up after the snow is gone, I will redirect it outside. I recover the heat and the moisture that way. There is some concern about off gassing from certain materials, but this doesn't seem to be an issue for us. Just the two of us for now. When the son moves in, I'll have his dryer vented out. There will be two apartments in this house then.
  8. wildwest
    Not an issue for us either, and it smells clean and fresh to me :)
  9. Huntindog1
    Huntindog1
    South Central Indiana
  10. TurboDiesel
    Yep same here. One cold, and the machine kept my sinuses open all night. I think there are a lot of people that need the machine and wont break down and get tested.
    Ive found if I set the moisture on high it will run out of water and dry me out if I sleep in. i'm better off on the next setting down
    savemoney and wildwest like this.
  11. Huntindog1
    Huntindog1
    I learned a lesson recently the humidifier Wick in the machine is important.
    I tried using last years Wick as it looked to be in pretty good shape.
    Even though it was in good shape I sprayed some bleach on it to sterilize it.
    Well the issue is the minerals from the water builds up in the Wicks.
    This inhibits the water wicking up in it.
    I noticed the machine not needing water and the humidity of the house was lower.
    I changed filters and big difference as the new Super Wick filter made huge difference.
    The old filter looked clean but was like petrified at the top of filter from the lime build up.
    Over half the filter wasn't getting water .
    My Humidifier uses a high performance wick thats like 280% higher performance than old type filters.
    http://www.essickair.com/humidifiers/ep9500-pedestal.html
    Important point if you use my type humidifier:
    There are other filters that work in this machine
    but you need to use the Super Wick version with the higher performance.
    Too get the same humidifying effect.
  12. savemoney
    Go on the web and shop around for replacement filters. I was able to find them for less than half of the price at the box stores.
