Flames in Ash Pan?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by wildwest, Nov 25, 2014.
  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I got old by being crotchety and not playing with fire without the 'bestos suit and gloves so to speak, so it is something I'll continue to be:p.
    Now it is time for an English Bitter.
  2. wildwest
    English Bitter is Better
    ivanhoe likes this.
  3. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    The first and only respone to those should have been, We have one and why did Drolet go from 3" to 4" on the air intake? That should have stopped him up short. The installer that put the holes in my house also put a screen on my OAK that blocked too much of the air flow. The ESW folks with the burn pot and gasket issues elsewhere are finding out all about air flow the hard way as well. A right sized brass bore brush works wonders on burn pot holes. I have slots in my burn put and they work well there also. I use one to get between the heat exchanger tubes as well.
    ivanhoe and wildwest like this.
  4. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Oh well not much going on tonight so I'm packing it in and heading up over the stairs after filling the roaster to keep the cat happy.
    Have a good evening.
  5. IHATEPROPANE
    IHATEPROPANE
    Not sure OAK from an enclosed porch is a good idea. It needs be outside...
  6. smoke show
    smoke show
    Pittsfield, Wi
    Suits you well. :D
    ivanhoe, will711, wildwest and 2 others like this.
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    wildwest it is hard to tell if the color of the ash in your stove is too black normally because the stove did not undergo a normal shutdown.
    I however believe there were likely signs of a upcoming issue on the firebox walls before things went into the ash pan.
    Now if the area where your OAK ends is not a ventilated one the guys are correct and you really need it drawn from the outside.
  8. wildwest
    No worries on the porch friends, it's more like a lean-to that keeps snow drifts off the front door.
    ivanhoe and IHATEPROPANE like this.
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    We don't want to be guessing, it is bad enough when you have several possible causes for a particular thing happening. We don't like to miss stuff so we try to nail it down.
  10. wildwest
    Here it is in all its glory before we bought this home. The carboard duct taped to the studs has since disintegrated from the wind blowing snow in :rofl: :lol:. Really, you can see sunlight through the trusses and the scraps used for siding, lots of fresh cold air (slightly tempered from the leaky old windows to the left, which I run 80*.
    ivanhoe likes this.
  11. wildwest
    Would you have a short list of things I might have missed before the avalanche?
    ivanhoe likes this.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I believe we have discussed them up thread, I don't have much information on the control board or on the flow rates of those blowers in the combustion air stream. Either the fuel feed needs a means to be changed or the air flow, we haven't got many choices at this point. If you need to burn x pounds of pellets at a set feed rate you need y amount of air(oxygen) , there is no real choice given how the beast burns.
  13. wildwest
    oh, I understand now, I was thinking something else. Thanks
    ivanhoe likes this.
  14. briansol
    briansol
    ct
    Everthing about this company is scary.
    Manuel is a Spanish guy. Manual is a document
    geeze
    if they can't even QA their website, who knows what quality went into their machines.
  15. wildwest
    Could that manuel be french?
    ivanhoe and smoke show like this.
  16. ivanhoe
    ivanhoe
    Northern Ontario
    Sounds like it to me. It also could be a trilingual manual.
    IHATEPROPANE and wildwest like this.
  17. wildwest
    SmokeyTheBear , I am under the ignitor and still no flap. Matter of fact I can feel cold air from the OAK. What do you think?
    IHATEPROPANE likes this.
  18. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Manual is out to lunch or there is something missing for whatever reason. Them's the choices, now how about a picture of the exhaust blower, if there are number we want them.
    There are all kinds of blowers and they have differing CFM ratings.
    I might spend some time reading through the manuals to find things that might be hinted at.
    IHATEPROPANE, ivanhoe and wildwest like this.
  19. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    já
  20. wildwest
